Can someone tell me if these tubes are replaceable or not ? While trying to remove one I managed to damage it badly. The thing that makes me think that they are not part of the case is the fact that they both sit at different heights inside the case. Are these screw in ?
Trying to unscrew the damaged one but it doesn't seem to move.
The reason I wanted to remove them is stupidity and the fact that it's missing a pusher so for some reason I thought that it was appropriate to try and remove the tubes. I've done a  booboo, I know.
I won't be attempting to remove the other, the problem is that the one that I tried removing is now really damaged and needs to be screwed out.
Any tips ?
Any tips ?
Unless there is damage to the inner side or how the pusher works, leave it alone.
21 minutes ago, Chopin said:
The damage is bad. It has to be replaced. I have to get it out. :(
You can use a screw extractor. Search Internet to see what is that. Heat well the case around the tube before and proceed carefully.
Edited by jdm
Equivalent tool for a much more reasonable price.
https://www.aliexpress.com/item/4000298591084.html
Lol. I was trying to be all watch maker uppity....the one you shared is actually the one I have. Ive learned that for every ridiculously overpriced watch tool there is a cheap chinese knock off. The trick is knowing when the knock off is decent enough. Some times the chinese knock offs arent worth the cost to ship them.
Sent from my SM-G950U using Tapatalk
Alright, I managed to extract what was left of the tube.
Guess what ? It was a freaking push in tube, not screw in.
I thought that those that have those little threads/spikes on the edges are supposed to be screw in... Oh well, another lesson learned. Thanks guys! Panic mode off. :)
I had tried pushing it out but couldn't so assumed that it's screw in.
Edited by Chopin
Feel free to add to:
Out of curiosity, is it possible to extract these push in (or should I say drive in) tubes without one of those expensive tools ?
Once I was able to install the tubes by using a crystal press (and improvising a bit) but don't know I could go ahead and remove the remaining one. The reason I'd like to remove it is to measure it so that I'll know what replacements to order... Do I even need to know the dimensions of that tube ?
Nice. Thanks for the tip. I could have probably saved myself a few bucks and heartache had I known.
I have done something like this before. I ended up using pliers to clamp the opening of the tube shut, creating a nice flat end for me to grab and twist, with said pliers.
    there are 2 types of  screw extractors available.  the square and the spyroll.   i like the square.    vin
    is there a "tool maker"  in the house?      vin
SEND ME YOUR SKETCHES
I HAVE CNC CAPABILITIES
  they are listed in any tool catalog  - you can make the square ones out of "key stock".  vin
Managed to remove both of them and they got damaged in the process but one pusher was missing so I'll get a new pair anyway. The thing is that I've looked a bit on CousinsUK and so far those on the website don't exactly seem to fit my required dimensions.
For example all pusher diameters are in increments of .50mm. Mine is 4,8mm I believe... Being bigger might not hurt but the hole diameter seems to be 5,2mm so I'm not sure if it'll be a safe fit. Same goes for other dimensions as well, hopefully I'll manage to pull this through.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
