Omega 561 Lubrication Chart Required.
Geo
Hi guys, I'm servicing an Omega Constellation with a 561 movement just now. I was wondering if anyone has a lubrication chart in PDF format that they could share? I can manage without, but it is always good to check these things if possible.
Cheers,
Geo!
Thanks for that Lawson, I appreciate you finding the link, but it doesn't appear to be working. Possibly because I' using my iPad. I'll check it out on my PC later.
As I said, it's not desperate that I get a lube chart, but as it's a friends watch I just thought I would see what Omega had recommended. It's probably the most impressive I've come across for build quality!
Edited by Geo
That particular calibre had a "special" run of 100,000 movements that came out extra accurate. Wonder if its one of those?
I did know about this and checked it out, but unfortunately it is 23xxxxxx instead of 24xxxxxx.
Here's a link for others to read, it's mind blowing accuracy!
http://ialreadyhaveawatch.com/2009/01/the-famous-100000-consecutive-omega-561-chronometers/
Found this info on the  Omega forum and was written by an Omega watch repairer
Some recommendations for oils:
Train either D5 or HP1300 for the larger wheels (most professionals use HP1300, but D5 is acceptable for those on a budget), and for the barrel arbor. Then 9010 for the 4th wheel and escape wheel pivots, as well as balance pivots. 9415 for the pallet jewels, nothing on the pallet fork pivots - they are left dry.
If you look at any technical guide for a modern movement, for example pick an ETA 2824-2, this will give you a good guide for how this movement should be lubricated. Yes lubrication can start holy wars between watchmakers, but if you want to follow the sort of oiling techniques and recommendations used by Omega presently, the 2824-2 technical guide will be a good start. Of course the automatic is different, so not all of it applies, but certainly the base movement oiling will be accurate.
Edited by clockboy
  • 2 years later...
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
