Omega 561 Lubrication Chart Required.
Geo
Hi guys, I'm servicing an Omega Constellation with a 561 movement just now. I was wondering if anyone has a lubrication chart in PDF format that they could share? I can manage without, but it is always good to check these things if possible.
Cheers,
Geo!
Thanks for that Lawson, I appreciate you finding the link, but it doesn't appear to be working. Possibly because I' using my iPad. I'll check it out on my PC later.
As I said, it's not desperate that I get a lube chart, but as it's a friends watch I just thought I would see what Omega had recommended. It's probably the most impressive I've come across for build quality!
Edited by Geo
That particular calibre had a "special" run of 100,000 movements that came out extra accurate. Wonder if its one of those?
I did know about this and checked it out, but unfortunately it is 23xxxxxx instead of 24xxxxxx.
Here's a link for others to read, it's mind blowing accuracy!
http://ialreadyhaveawatch.com/2009/01/the-famous-100000-consecutive-omega-561-chronometers/
Found this info on the  Omega forum and was written by an Omega watch repairer
Some recommendations for oils:
Train either D5 or HP1300 for the larger wheels (most professionals use HP1300, but D5 is acceptable for those on a budget), and for the barrel arbor. Then 9010 for the 4th wheel and escape wheel pivots, as well as balance pivots. 9415 for the pallet jewels, nothing on the pallet fork pivots - they are left dry.
If you look at any technical guide for a modern movement, for example pick an ETA 2824-2, this will give you a good guide for how this movement should be lubricated. Yes lubrication can start holy wars between watchmakers, but if you want to follow the sort of oiling techniques and recommendations used by Omega presently, the 2824-2 technical guide will be a good start. Of course the automatic is different, so not all of it applies, but certainly the base movement oiling will be accurate.
Edited by clockboy
  • 2 years later...
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
