Low escape wheel
Ammar
Hello,
I am working on a Citizen 8200a movement that was running slow, I took it apart cleaned it and started putting it back together but the escape wheel decided to troll me and sit lower than the pallet fork and not even reach the bridge and the second wheel.
I checked the pivot,the jewel (which is flush with the face of the plate i thought I somehow have pushed it down but apparently I havent and it's not broken) and the bridge ian't bent and what is annying me is the watch was running.
By the way the main bridge or what ever it's called on this movement is a pain in the neck to put back in place I don't like it.
56 minutes ago, oldhippy said:
Did you remove the end stones if any? If so have you put them back in the right order. I would like to see some photos as I can't remember much about this cal movement, both side of the plates please.
There is no end stones on this movement (I have done this mistake before ^_^)
2 minutes ago, watchweasol said:
Hi Ammar  just a thought  if there are no jewel settings to have moved, Have you fitted the wheel upside down therefore putting the wheel on the wrong plane ?????. I have attached the tech sheet to help you
Hi I fitting the wheel the right way I am sure of that, I have a couple of spare wheels from another movement I'll see if the fit and have a try although the pivits on this wheel looks absolutely fine but I am out of ideas
49 minutes ago, watchweasol said:
Hi Ammar another thought and I have done this my self when rebuilding movements, Is the fork/pallet the right way up if not it would be the same , out of line.
I think you are right on this, or the pivot has been replaced at sometime and slipped in a tad further than was first fitted..
14 hours ago, Ammar said:
Hello,
Sure you got the other wheels in the right way up or in there jewels . Could be tricky to get all pivots in place. And the click is in place on the ratchet wheel.
3 hours ago, Ammar said:
uh um the second wheel pivot snapped on me yea... I hate this movement
Not the easiest to align all pivots on this . Has snapped pivots to. BTW which wheel do you mean? The wheel for the second hand don't have a pivot . Sweep second pinion it's called.  Think it's a spring that holds it down or up .
I meant the wheel that meshes with the escape wheel I was so frustrated when I made that comment didn't think of the terminology (not that I know what it's called any way).
I have another spare movement coming my way hopefully I can get it right this time  ^_^
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
