Hello,
I am working on a Citizen 8200a movement that was running slow, I took it apart cleaned it and started putting it back together but the escape wheel decided to troll me and sit lower than the pallet fork and not even reach the bridge and the second wheel.
I checked the pivot,the jewel (which is flush with the face of the plate i thought I somehow have pushed it down but apparently I havent and it's not broken) and the bridge ian't bent and what is annying me is the watch was running.
By the way the main bridge or what ever it's called on this movement is a pain in the neck to put back in place I don't like it.
Did you remove the end stones if any? If so have you put them back in the right order. I would like to see some photos as I can't remember much about this cal movement, both side of the plates please.
There is no end stones on this movement (I have done this mistake before ^_^)
Are you sure the pivots are OK on the escape wheel.  If you just have the wheel between there plates and screwed down, does the wheel run true?
2 minutes ago, watchweasol said:
Hi Ammar  just a thought  if there are no jewel settings to have moved, Have you fitted the wheel upside down therefore putting the wheel on the wrong plane ?????. I have attached the tech sheet to help you
Hi I fitting the wheel the right way I am sure of that, I have a couple of spare wheels from another movement I'll see if the fit and have a try although the pivits on this wheel looks absolutely fine but I am out of ideas
49 minutes ago, watchweasol said:
Hi Ammar another thought and I have done this my self when rebuilding movements, Is the fork/pallet the right way up if not it would be the same , out of line.
I think you are right on this, or the pivot has been replaced at sometime and slipped in a tad further than was first fitted..
14 hours ago, Ammar said:
Hello,
Sure you got the other wheels in the right way up or in there jewels . Could be tricky to get all pivots in place. And the click is in place on the ratchet wheel.
3 hours ago, Ammar said:
uh um the second wheel pivot snapped on me yea... I hate this movement
Not the easiest to align all pivots on this . Has snapped pivots to. BTW which wheel do you mean? The wheel for the second hand don't have a pivot . Sweep second pinion it's called.  Think it's a spring that holds it down or up .
I meant the wheel that meshes with the escape wheel I was so frustrated when I made that comment didn't think of the terminology (not that I know what it's called any way).
I have another spare movement coming my way hopefully I can get it right this time  ^_^
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
