WWW Eterna sucked me in.
luiazazrambo
I have thousands and thousands of unsorted watch crystals. Started to measure the first 100 of them but its a slow process. Not sure if this tool will help as it is just arrived and I am about to leave for holidays... (no watchmaking for more than a month...), will try to use it. Even if it is not going to be practical I still love it.
Edited by luiazazrambo
  • 2 months later...
Let me introduce my new light box: Behemoth No 1.
I got the idea from youtube where someone was converting broken LED TVs to provide realistic artificial daylight. I thought that it could work with photography - you actually can buy different sort of light boxes - so I could take pictures of watches and if it is a bit bigger then clocks too. So I went for a hunt for broken LED TVs on FB marketplace. After countless hours of work I ended up with this monster now I struggle to find a place for. The size was determined by one of the LED TV where I cut the screen layers into half providing light from the two sides and there is another LED TV screen on the top.  Power supply came from the skip, just like the plywood and the pallet wood. I had to buy the LED strips and the background. Considering the number of working hours, the trips you have to make to collect the TVs and to dispose the parts you don't want, the money I spent on the strips and the background probably you would be better of if you just would buy one of the ready made ones from ebay you can put into your backpack.  🙂 Of course you would not have the fun I had and the glory now. 🙂 Here you can see the details of my Behemoth, I bought black, white and red backgrounds (45 cm wide 1,5 m long felt). I can separately switch on and off the two sides and the top. For demonstration I actually used a galvanometer and a cat called Smudge. 🙂
  • 4 weeks later...
5 hours ago, dadistic said:
Those boxes are really nice, especially the one with the felt liner. I have some similar wood boxes that I use for watch stuff, but they don't have dividers and neat little tops with handles. Maybe I'll have to make some!
Cheers
Yeah I thought about that too but it would take a lot of time and I am not sure if my woodworking tools are precise enough or if have the right tools and the knowledge to make them. Should I have the time, knowledge and the tools I would also make countertop display cases and a wood engineering toolbox.
Failure, I cracked it, i was pretty close though. The internal voice was there but I didnt listen, I should have heated up some tools as it is advised, with that i would have had better chance.
Never replaced a balance staff, it is beyond me...
  • 2 months later...
One step closer to become the "Crystal man". 🙂 These are also from Germany. Acrylic watch "crystals" made for Kienzle, Laco, Speidel etc. I kind of see burn marks on the tools. Does that mean that the tool was heated up to ease the forming?
https://en.wikipedia.org/wiki/Kienzle_Uhren
https://en.wikipedia.org/wiki/Speidel
https://en.wikipedia.org/wiki/Laco_Uhrenmanufaktur
Nice, they gave you the tooling to make as many crystals you wanted. The iffy alignment of the lettering and occasional spelling errors remind me of my own work. They made precise dies but couldn't make punch guides?
Yes, it seems that they sometime not found the letter "I" for India and they used the letter "J" instead when they wrote KIENZLE, and they forgot the N once, but then they squeezed it in later. 😄 It was probably not so important to make them pretty, thank you for the video though. I wonder if these dies wore out or not. There were many watch crystal makers in the UK in the past I don't know if there is any left, I would not think so.
Almost certainly. The most likely method of production was thermoforming, possibly assisted by vacuum (hence the holes in the dies) or blow mounding (positive pressure).
Probably not on anything like the scale in the video below, but the process is similar.
You can buy, or make your own small scale injection moulding and vacuum forming equipment.
Lots of other videos, but those will give you the basic ideas.
Edited by AndyHull
On 1/21/2022 at 1:57 PM, luiazazrambo said:
Edited 21 hours ago by luiazazrambo
Interesting construction. From the picture, it looks like there are possibly multiple parts to each half of the forming tools.
If I am correct then there may be a hardened collar, to keep the wear to a minimum, pressed into a blank holder made from cheaper mild steel.
Also the form would probably make a crystal with a large brim a bit like a bowler hat, which might then have the brim turned down to an exact size in a secondary process.  31.7mm  diameter with a 0.9mm wide brim in this case.
Perhaps the idea was that you produce 31.7mm +1.8mm result and machine these down to 33.4, 33.3, 33.2 etc (334, 333, 332  etc crystals)
My suspicion is that these were intended for production of reasonably large volumes of crystals. Perhaps runs of a few  thousand per tooling.
If you only need a handful then you could have used a single part construction as wear would not be a factor.
I envisage an electrically  heated tool, with perhaps a vacuum hose or air hose to push or pull the material in to the mould, with pre-heated (with hot air perhaps)  square blanks cut from sheet being presented to the machine individually, and pressed between the tool halves with a small hydraulic press. A bit like a die stamper. The vacuum or pressure hose may not be required as the acrlic blanks would be small and relatively thin.
The pressure of the tool alone may be sufficient to get good results.
Not a very high volume production process perhaps, but good for one crystal every couple of seconds.
You could maybe replicate the stamping with a drill press and suitable tool holders as the pressure wont be very high when dealing with softened relatively thin, pre-heated acrylic sheet.
Don't be tempted to simply roughly line them up and whack them with a hammer however as if they are hardened steel they may not survive the process.
Edited by AndyHull
Another topic. Ronda RL 1223 with alarm function. Got a few of these NOS movements in protective sponge cover. 🙂 Most of them are relatively clean and most of them even start in this state, of course all need a service. I need a case a dial and a set hands now, anyone want to swap these for a movement?
http://thewatchspotblog.com/?p=215
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
