ETA 2472 Oscillating weight too much end-shake
By SwissSeiko · Posted
The price of tools in this industry is really getting out of hand. might need to take a second mortgage -
The extra holes in the base of the tool fit the plastic die and the new pusher holder perfectly as well, so no need to keep track of the extra parts -
Making a stud pin for a pocketwatch from 1mm copper wire, softer than brass but it will do the job. The lathe cost 3 pound including the chuck, powered from an old electric shaver adapter. -
By LittleWatchShop · Posted
Demagnetizers work on the principle of a decaying magnetic field. Whether the expensive Elma or the cheap Chinese...same principle. For the cheap ones, you are decaying the magnetic field manually by drawing the watch away from the demagnetizer while it is energized. The Elma (and others) generates a decaying magnetic field electronically so you don't have to do the work. If you use the cheap ones properly, they will do the job. I prefer the Elma style...but that is just me.
