It's the little things in life
My wife has had a jumbo size jar of pickles of the bench for the last 2 months that has defied all efforts to open it.
Bought a new Silicone jar opener, made no difference.
Holding the jar at 45 degrees and slapping the bottom of the jar to use the 'water hammer' effect didn't work.
Me holding the jar and my son trying to open it didn't work.
Heating the jar lid with me holding the jar and my son trying to open it didn't work.
After coming home tonight from the pub I could see my wife had tried to open it again without success.
I gave up and searched the web for how to open stuck pickle jars and one suggestion was use a bottle opener on the side of the lid.
I very carefully used my best bottle opener (Hand forged by a blacksmith) on the edge of the lid and 'pop' went the lid without the lid being damaged.
The jar is now open after 2 months of trying, is there anything the web can't help you with?
:D
 Air needs to get in, since the jar has to a good extent been vaccumed, it is heated and the sealer lid is preesed on, as it cools a relative vaccum inside creates suction if you will, that is like strong  pressure from the outside pressing on the lid.
Proper proceesing is of high significance, on jar, bottling and canning lines alike, since in addition to the processed content, the consumer health and producers repution is on the line, processed food safety is No one concern in modern societies of today.
Other techniques in industry is to preesurize the inside with like nitrogen gas, inerst to the food stuff. Which is probably used in your coke and beer bottles, depending on the country and regulations.
You can also tap on the rim of the lid, to disfigure the lid enough for air to get in.
Best
Edited by Nucejoe
Not from internet, imported bottling line for son in law, kronas of Germany.
The best solutions are normally found after a visit to the pub.
I've watched enough episodes of Morse to know that there's not a problem known to man that a beer can't help to solve.[emoji3]
Sent from my moto g(6) play using Tapatalk
Seafoam!  In the tank and the aerosol can into the fuel rail.  (If you can get Seafoam where you are).  Also freed the stuck valve on my '93 Pathfinder and their Deep Creep penetrating oil is the only thing I use on anything from tractors to rusted motion works!
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
