Hello there,
Ive been on here with quite a few posts in regards to my seiko 7002 watch movement.
Im brand new to horology and wanted to open up my watch and see how it works. the amount of components that broke in this process is ridiculous. Last night after receiving my new escape wheel in the post. i had completely reassembled it and yet it still didnt work. At this point i wanted to launch the watch as far as i can out the window and was on the verge of tears. i sheared some pins on my watch dial face and now that is only held by one pin. i had ground one of the plastic wheels for the calendar change and a click spring almost pierced the metal cover plate.
I had finally give up until i found out that my pallet fork was jamming the flow of train wheels and amended this. I was so relived that it was finally in beat. The satisfaction of getting this repaired was great!
Where can i source a new navy blue dial face complete with pins from?
EBay is the obvious suggestion but you'd likely have to buy a complete watch.
However, if you plan to continue this hobby, get yourself some dial dots and use one or two on the side where the pin came off. They'll come in handy for future watches.
You could also try to solder the dial foot back on.
Thank you for your advice. Never thought about soldering, great idea.
What are dial dots by the way?
Hi   If you are considering  resoldering the dial feet/foot back on be careful not to mark the dial face. I should look up re soldering dial feet on the net and how to do it.  there are two methods using a small blow torch and transfering the heat down the foot to melt the solder chips,  or what is known as cold soldering using a dial foot machine which is in fact a low power arc welder. Both methods are explained on the net.    Dial dots are self adhesive pads they are double sided to enable you to place a dial on to the front plate securely, dont work on all watches because of the calender and date work, again this method is explained on the net
Pretty much as Watchweasol above says.
I should have asked if your movement has a day wheel of course as that would mean dial dots wouldn't work, but they're small dots of double sided thin adhesive material that stick the dial to the movement and can be purchased in sheets from material houses.
Re soldering. I haven't tried it at all so please heed the useful advise in the thread above.
i suggest you DO NOT try and re-solder the dial it is not an easy task and if you dont have extensive soldering experience you will just damage the dial even more to where it will no longer lay flat on the movement. you can take it to a jeweler to do this.
as far as getting a new dial. Seiko does not sell dials individually but there are plenty of aftermarket dials for the 7002, but if you are a stickler for original you can buy a parts watch or there are sellers from phillipines that sell used 7002 dials but most are pretty beat up and nice ones do just as much as parts watch so mine as well go with that. another great site is speedtimerkollektion just type that in the google search to get to their site.
There is a good chance your dial may be aftermarket if it already is than just get the AM dial for $15
Hi all,
Thank you all very much for your advice and feedback.
I have purchased another aftermarket set of hands and dial from somewhere in the Philippians.
I will have a go at the dial dots to begin with but if they do not work then ill just put the new one on.
When you receive it these please post  picture next to a genuine set. Very welcome to check lume also.
Sometime these are pretty good, sometime they are not, although the end we are talking about very affordable watches as mentioned there is always a  more or less evident issue of authenticity/unmolested status that triggers enthusiasts.
Edited by jdm
BTW. Dial dots are nothing but bi-adhesive tape already cut to small rounds. Actually one can cut it to custom shame with better results
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
