Trouble pressing case back on.
Examine the case back for burrs and damage.  You may need to lightly polish the edge of the case back rim with fine grit or a fine file to remove corrosion or other debris that is making things difficult. Ensure everything is sqeuaky clean before you proceed. The rear of the watch should be immaculate before you even attempt to put the back on. Any dirt or debris will find its way to the dial side eventually.
Check to see if there is a particular orientation the back is meant to fit in.
Apply a small amount of suitable grease to the edge of the back. Use a crystal press, but ensure you are  pressing on the body of the watch not the glass, as you don't want to damage the crystal.
Ensure everything is completely flat when pressing back on, and I do mean completely flat. The fit is often very tight, so if you have things slightly off true, then it will never go back on.
Edited by AndyHull
Another little thing as well as the above mentioned is make sure the caseback die is big enough , a to small a die tends to just exert pressure on the middle of the caseback therefore flexing the caseback edges out a little thus making the back bigger and harder to get on . You want the die to be as big as the caseback really and as also mentioned , some can put up a good fight
I use a drill press.  Plastic to protect crystal and case. Using  the largest socket that covers the case back ,I press the Chuck into the socket and press down. Plenty of leverage. Works every time.
Hi AndyHull,
Please, what would be a suitable grease for that, in your opinion? Would any of the greases we already have be good? Moebius 8200, molykote, or plain industrial vaseline?
I don't think grease will help, pay attention to what Ancyclient wrote above, the die must press on the perimeter only. You have a lathe so no problem for you to make a better die if needed.
Edited by jdm
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
