Hi all, I have just dug out this elderly Favre Leuba twin power in the hope of reserecting it. It won't wind and is pretty gummed up and dirty. I have stripped it down and marked the springs in case they are different? As it's brass (I think) I am not sure as to what is the best way of cleaning it up ? I have taken photos and enclosed a few for your opinions as to how to go about it. Many thanks in advance.
I give it numeriois clean.
First, Soak in kerosene for several days and brush, kerosene is brass friendly for life, gives off bad oader, dosn,t evaporate but the lid on the jar,, then soak in paint thinner like  ten mins and brush after each soak,  Every part including the regulator arm is got to come off, I even brush the jewel housing. Keep repeating, three our four good brushing, soak - brush , this brings the shine back, no power drill to brush, just manual. tooth brush would be the roughtest brush you use on plates and bridges. You will start to see clean shiny parts perhaps after three or four clean.
Once looks clean, it is ready to go into your cleaning machine or general cleaning so to speak. This jewel is worth it.
Best wishes.
Best wishes.
Hi NuceJoe and thank you, watch parts sitting in a jar of petrol now ! Will follow your advice. Being brass I wasn't sure what to do and didn't want to ruin it through ignorance. Hopefully I can get it running again. Thanks for your best wishes.
Diesel fuel would work too, brushing in solvent helps. I use several solvent seperately, each will do some good.
Long time soak in paint thinner or carburator cleaner is harmful.
Paint brush is suitable for use on gears, pinions.
Shellack on pallet jewels and impulse are is susceptible to damage by solvents.
I am talking ebauche and gears cleaning only.
Picture shows Shock springs on cock and the mainplate diferent, should be the same.
12 hours ago, Johnnie said:
As it's brass (I think) I am not sure as to what is the best way of cleaning it up?
Virtually all watch plates are made of brass or similar alloy, then may be plated with different finishing.
Anyway petrol and alcohol based solvent are good to clean but will not make it shine the best. For that, if it matters to you, use ammonia based solutions, either off the shelf or you cold make your own with household products, in any case be careful to avoid high concentration or long baths.
Hi Jdm, I didn't know most were made of brass and then plated. We live and learn! If I can get it clean then I will settle for that. Many thanks for your input.
Very true,
No matter how hign tech the plating on the base metal, there are pores or scratches, in the palting, through which solvents can penetrate to chew on the base metal. So one should be concerened with long term soaks with reactive solvents.
kerosene or Diesel fuel don,t chemically react with the base metal, it dose penetrate through the pores  slightly( no reaction), you just remove the penetrated( wetted surface) surface with brush, resoak , brush again, you are cleaning physically, ( no chem reaction) .Solvents chemically reactibe with the base metal, should only be use for  very short time and brushed and rinsed immediately.
You will see some clean by the first brushing, what news I have , is kerosene works. You are not limited to one clean, no harm with second or more clean, Once visibly clean, time for the final clean in your machine or whatever method you choose.
I am staying with yoir thread, I don,t see why this service can be less than percect.
How dose the rest of the watch look? Dial, hands and case. Rare piece.
Regards
    diesel and kerosene are basically the same !  NOT the best solvent - for cleaning today. BUT, it is CHEAP.   VIN
Hi Joe, the case and crystal are good, the case back is ok but a little scratched, the dial is good but probably it has been refurbished. ??? If it has been refurbished it's been done far better than I could do it, so I'm not complaining.
acetone and alcohol should also be avoided when cleaning pallet and roller jewels.
use naphtha (ronsonol lighter fluid) cheap and you dont have to syphon any out of your car lol
Edited by saswatch88
3 hours ago, Johnnie said:
Hi Vin, yes it's very cheap, I syphoned it out of my wife's car !
  good show !  now sypon some petrol - add the two 50 / 50,  try that.  :)  vin
I dislike to clean anything with diesel fuel. It's greasy and smells bad. And in the US isn't even cheaper than petrol.
Done ! And running, it's 02.22 and my eyes are like organ stops. It turned out ok and I am pleased with it. Many thanks for all your help and advice. Ps, it's very good on petrol ! :D
Great job cleaning it up.. do you have a case ring for it?
I have a similar watch and the case ring was cheap white plastic hacked up to fit. Works but not pleasant to look at.
Anilv
Anilv
Hi Anilv, that is the only bad thing, when I got the watch the case ring fell out in three pieces. So will try and sort something out for it.
I have just noticed on the left of column there is "a tick, a triangle, and a zero" ? What is that about ?
That is when one really wants to have a small lathe. Someday...
That's for sure Jdm, At present I have "the basics" my next three things have GOT to be are Mark's course, a timegrapher, and some sort of parts washer, my mind boggles at all the different tools required. The more I learn from this fantastic forum the more tools I need. Being probably one of the least knowledgeable people on this forum my head spins at times. I freely admit when I joined that I destroyed many cheap eBay purchases that have become my parts department :D but have been successful in rebuilding four Seiko's and that's given me enough pleasure to get more serious. (Now addicted)
1 hour ago, vinn3 said:
   i would place a lathe at the top of the list of things to buy to work on watches.  vin
Indeed so, if I were more knowledgeable Vin, at present I am an enthusiastic tinkerer, so Marks complete course must come first. Aim to subscribe in the within next few weeks !
The triangle is to vote up an answer.
In the topic index there is a 'pinned' post explaining the Vote Up function.
Anilv
16 hours ago, Asmobrat said:
Well... I tried contact cleaner and rinsed with blade oil on Seiko 6309... It worked well... Especially the rust residues...
 Contact Cleaner  might  be good  if you remove the balance assembly first.  vin
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
