Hopalong Cassidy - NOS Replacement Strap
JerseyMo
No, I don't collect the vintage character watch series made by US Time and Timex.  But I have restored a number of them and typically the strap is missing or well worn.  Some had very distinct straps and trying to find a suitable replacement is not easy.  Ah but, what if you could find a NOS?  Not so easy to do and I thought I never come across one for the Hopalong Cassidy.
You know the one with the big buckle and metal tip.  Than I get in a huge NOS lot from a retired salesman and found this >>>>
Edited by JerseyMo
typo
  • 4 weeks later...
Some things are just meant to be and that strap had your name on it. Well done!
Is it just me but, somehow I feel a little sad when I have to separate the strap from an old watch that have been together for goodness knows how many years. I have just stood in front of the waste bin with the strap from a watch that has been worn to the point it had assumed the shape of the owners wrist. The fastening hole was elongated by many years of use. I felt genuinely guilty about letting it finally drop into the bin. I can’t help but think about the person who might have owned it, the places it has been and the stories it could tell. I think I must be getting more sentimental with age.
You could, of course, attempt to restore the strap. Some of the leather ones I've encountered did actually restore quite nicely.
I even re-stitched a couple of them. Others however are so badly worn that they are beyond hope.
1 hour ago, Davey57 said:
Yes I have rescued one or two, but some are so disgustingly ingrained with “stuff” I could not bring myself to use them.
yep, as with all straps and bands there can be some seriously funky stuff growing in there!
  • 2 years later...
I cant say I had no difficulties. I was ready with the one you can see on the pics once then i was checking its performance on the timing machine it looked brilliant so i tried to regulate it while i was working from home. Just a light touch with my tweezers reaching it over my computer.... my tweezers slipped and i literally destroyed the HS. I was so sick I could not revisit it for about two days. I sourced another HS and as far as I remember I also ruined the pin pallet while I tried to clean it so I had to source that too. (the pins were stuck in rodico and the rodico pulled one of them out when I tried to lift the fork up, i put the pin back but it was not tight enough anymore) You can buy ladies watches with M21 on eBay for about £2-£4 as a donor movement. I have serviced another M21 since this one and another two M22s are on my desk. Just like with anything else everything gets easier/quicker to handle if you practice it. Originally I could not even imagine how to put the main plate back and now I don't even consider it as a difficult task, it usually goes back all right for the first try.
Edited by luiazazrambo
11 hours ago, magic2020 said:
Got one just like that as a present in 1956  (I'm 75), but hesitant to do anything with it in case I fail miserably!
Maybe one day?
If you need advice or parts let me know I am going to try to help you the best I can. Take care.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
