Hello Everyone
jmm109
Hello, my name is John and have been semi-retired for 5 years. I have been interested in pocket watches and wristwatches for some time now.  I was trained in high school to be a classic repair shop/jobber machinist and spent my career in the mechanical trades, my last job used cranes to do engine disassembly now in my hobby I use tweezers for disassembly.
 I have learned a great deal from the videos Mark has posted and would like to keep learning new things from the wealth of knowledge possessed by Mark and the members here.
I have recently taken a 2 day pocket watch class (disassembly, cleaning and reassembly) at the NAWCC in Lancaster PA, USA and had a great time, our instructor Drew Zimmerman (CW21) was fabulous. Now I am addicted and buying tools.
Thanks & Stay Safe
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
