Small staking set (no frame)
I just bought this little set at a mart and am wondering exactly what I have and whether the necessary parts are there to use it. It's obviously a small swiss staking set (Star brand), for watchmaking I presume.
There's a large round flat stump on the right, screwed into a hole in the box, for hammering on I suppose.
There is no frame, just a die plate that fits into a round "holder" as you can see from the photos below. Under the die plate are holes around the outside that fit into the knob in the round holder center recess to secure the die in place. The other hole in the round holder center recess allows the 4mm stakes to fit through. The larger round hole in the center recess is possibly just to fit onto the placement rod at the center of the box, to prevent the assembly from moving around too much when stored inside?
There is a long piece on the left that is meant to be secured in a vice, which has a flat surface on one end, and a taper with hole in the center at the other end. The stakes are 4mm in diameter and don't fit into the hole in the tapered end.
Is there something missing and if not, how is this staking set meant to be used (as opposed to a more usual staking set with a frame, which I have).  I suppose for small staking jobs that could be done on a bench and would not need the perfect perpendicularity that a frame provides for the stake hitting the work?
I also attach a catalog listing of a similar tool from the 1920's, in France.
Thank you, in advance, for your insights and expertise.
Super interesting!! I hadn’t seen any staking tool without a shaft to guide the stakes. There has to be a away set things up. I wonder if these sets are more accessories to a basic set rather than the whole tool by itself.
I’m interested to learn more about this! Let’s see what the gurus have to say [emoji1303]
Hi rstl99   Yes it looks all there apart from a few gaps these are ok for general work, for balance work etc you need the  proper up right staking tool with rotating table and punches.  If you google watchmakers stanikng set or do the  same on ebay you will see what I mean therer are many makes K&D Star and many more.
Hi everyone and thanks for your feedback and suggestions.
I do own a full sized K&D Inverto staking set with all the necessary stakes and stumps.
But I had not seen a pared-down little staking set like the one I just bought.  Indeed, it has similarities to the one for clockwork showed above, but mine is quite small and dainty, and suited for watchwork (stakes are 4mm diameter, and some have very tiny holes in the centre).
A few months before, I had bought from the same seller a small set of stakes that I now realize were an accessory to this recent staking set I acquired.  In combining and organizing the stakes I made up a pretty complete set, and filled out the box containing the die plate and two flat anvils.
I'm thinking that perhaps there was a time when all staking sets were like this, before the companies invented the frame holder which aligns the stake to the die plate.  And that some watchmakers liked to use the frame-less set for some tasks, so companies kept making them (until the 1920's anyway, based on that catalog entry).  And that for some tasks, the simpler die plate and stakes are all that is needed.
Anyway, I'll use it for odd little jobs (maybe repairing fusee chains) and eventually will discover tasks it's well suited for.  I haven't yet seen such a set described in any watchmaker book that I own, as the staking sets described are always the ones with the frame.
Cheers.
For anyone still looking at this thread, my little research has only yielded that such a set was called a "set of punches".  It seems to pre-date the "staking set" that we are all much more familiar with in watchmaking parlance.  Although similar but larger "punch sets" are still made and sold, for use in clock repair (as one of the photos above attests).  For watches, the staking set reigns supreme.  However there are no doubt some situations where a "set of punches" like the one pictured above will prove useful.
  • 3 years later...
I had this type and many more like it, the center piece/block is used in the same way as if it had a stand. Hardly ever used it for watch work, as I had two sets complete with the stands. Centering was a bugger.
Edited by oldhippy
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
    • Sorry to jump in here, but I didn't want to start a new thread when there's already one regarding the second hand watch market. Can anyone tell me what I should be looking at when buying watches from eBay? I see loads on there for quite cheap, but after reading this thread I'm guessing they're all garbage and not worth the time? I recently bought an old Elco watch for 99p, just to practice on. I'm also really fond of the look of Services watches and Smiths Empire watches. I keep seeing them listed for around 5 or 6 pounds. Are they not worth the time buying? I'm not looking to sell watches to make a profit. I just want to buy watches I like the look of and wear them, but I also don't want to buy things that are going to be impossible to find parts for, or that have already been abused by someone else and broken beyond repair. Any tips?
    • I tried the Moebius 9415 from any sensible amount, down to microscopic a drop (or "super minimalistic"); the size of droplet which makes you really wonder why one would/should apply anything at all? But to no avail, consistently a lower amplitude compared to my Dr.Tillwich 1-3. Of course, as John mentioned above, the Dr.Tillwich 1-3, just like the Moebius 9010, likes to go somewhere else. Since short however, I'm the (proud?) owner of a bottle of Moebius Fixodrop. Can't say that I'm a proud owner of the 9415. So far, I haven't seen or discovered the "magic" of the 9415. Meanwhile, Moebius 🤣 has my money though.........
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
