The "trick" to most full plate 18s watches in disassembly and reassembly is to do it upside down. Once you remove the balance and mainspring barrels, remove the plate screws and invert the movement in your holder. Carefully separate the plates, teasing the pivots from the jewels/pivot holes. The pallet actually sits partially inside the lower balance jewel cock. Reassembling is the reverse process.
