Which balance staff for Omega 26.5T3 ?
mikepilk
I've got an Omega 26.5 T3 (non-Incabloc) with both pivots broken on the balance staff.
There appears to be several versions available - Incabloc, normal, short, long.
I've found Ronda 1855, 2796, 3880
Can anyone help as to which I need, or do I have to push out the old one and try to measure it ?
Are all dimension for the three you listed the same?
Expectedly different size  rollers and H/S collets .....etc   .
You will remove the staff anyway, the right choice/ requirments  can then be determined with certainty.
Regards joe
4 minutes ago, mikepilk said:
But with both pivots missing, and two of the staffs only 0.05 mm difference in length !
I might be able to do it on the width at the hairspring collet.
Right,  reffering to the model clockboy just posted, you also measure G the roller diameter .Though the pivot ligne( diameter) is not available to measure, other sizes are enough for selecting exact correct one.
Measure as best you can. I purchased a balance from Balancestaffs.com and it was the wrong size. Its not their fault though...these older movements are difficult to source parts for. I looked up on J Borel and BestFit MATSYS and they both say 100/594 balance staff, but I can't fine the dimensions. If the Ronda is easier for you to get, then go with the 2796.
1461019129_Screenshot2018-10-20at3_06_47PM.thumb.png.a4409917b0df437ef6fbf7a758f27a92.png
Assuming the staff in the wheel you got was the correct one, Correct dimemsioms being the main issue,  the difference in pivot diameter 11.75 and 12 are not expected to produce beat error or problems of the sort, or even if we assume all the .05 mm difference in length is in section B, no fault is expected form that either.
I think larger  forced into the wheel would have a roll in the wheel deformation, I am not sure though, perhaps experiences of Clockboy or OH comes to help and answer this.
Inserting  any linge 12 pivot into the jewels answers some questions, for instance you can see the pivot end coming out of the reverse side of the jewel or not and how far it sticks out.
 All staff sizes are available,  further response coming in will help.
Regards joe
2796 is for incabloc is 327 long
1855 non incabloc is 310 long
But there is also a version for 26.5 that is 1856 that is 332 long
All in my Ronda book . The 3880 i can't find under Omega.
Found this and hope it can help out as the dimension on the collet is different. Maybe you can figure out which one you need by measuring .
https://www.ebay.com/itm/Omega-balance-staff-26-5-26-5T1-26-5T2-26-5T3-100-axe-de-balancier-Unruhwelle-/201826585959
Edited by rogart63
I found that on ebay too - that's why I mentioned the collet size.
Bestfit online is nice but sometimes the physical books are nicer. So 594 is listed as non-Incabloc. Then the problem with finding the size of the staff is you have to have an idea of how long it is. So I've attached images for the 594 staff size and the equivalent balancestaff.com staff and its size. Then one of the problems with aftermarket replacement staffs even if they're made for a specific watch is they tend to vary a little by size. Usually there physically bigger to allow you to reduce things to fit. It's why the length isn't that important the pivots can be longer and then you can just shorten those. So it's always important with balance staffs to measure what you are taking out and comparing to what you put in to avoid unpleasant surprises.
Then because of the confusion I'm also listing of the Bestfit Incabloc number and its size just so you can compare to whatever.
OME 26.5T3    100/594    STAFF/OME 26.5    BESTFIT BALANCE STAFF
OME 26.5T3    100/857    STAFF/OME 100    BESTFIT BALANCE STAFF  Incabloc
100/857
A  327
B  160
C 90
D 50
E 43
I've just measured the staff.  I Haven't removed it yet, so had to use digital verniers instead of a micrometer.
.... and realised that the roller and collet diameters (G and K above) the same for all the staffs !
My measurements are collet 49, roller 41.
I found this on an ebay ad :
If 2796 and 3880 are only for Incabloc, then it's got to be 1855/6. And from the collet sizes, it looks like Ronda 1856 is the one ?
Edited by mikepilk
100/857
A  327
B  160
C 90
D 50
E 43
Yes I like physical books myself, but it's hard to beat online reference tools for convenience. Great, You found the measurements for 100/594! One thing you mentioned is the fact that many aftermarket staffs tend to vary, but keep in mind not everyone has a lathe or Jacot tool to shorten a staff or reduce a pivot--not trivial!
J
J
The 100/594 looks almost the same as Ronda 1856 - length 330 v 332, collet/roller diameters only 0.01 difference.
I'll go for which ever I can find.
I don't have a lathe, but do have a Jacot tool, so can only do minor adjustments.
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
