Old Elgin Losing Time
You need to post pictures from a timegrapher or equivalent application,  If it could be possible that some application could read your files or even interpret from playback, but that would never be good as a first person observation.
Otherwise all you could read here are generic statements like "clean and service the movement" - which in fact should certainly be done, or "something is touching and ringing", again you will not know what until the mov.r is taken apart, cleaned, inspected and lubricated by a competent person.
If you have been looking after your watch, I would say a good service. It is quite old and the mainspring could be tired, therefore the movement will not work on poor power this its self would cause the watch to keep poor time.
Did you make the movement spacer yourself with a 3-d printer? How has it held up with regards to the material.
I've been thinking about getting into this but I've heard the cheaper DIY material is not stable.. ie degrades.
Anilv
Thanks guys,
JDM- I don't have a timegrapher, I do this for fun. It is interesting though that your answer is similar to one I received on Timezone also in the watchmaking and repair forum. If I was working on an antique car and posted a question on a forum I would get a ton of answers and opinions of how to fix something, but in watches the answer is almost always the same, go to a watchmaker or seek a "competent person". I am involved with watches because I enjoy it, of course I could just pay someone to do it for me but then it's not much of a hobby is it?
oldhippy- Thanks, I have ordered a new mainspring but because the sound almost sounded like a pinging I was hoping that might be familiar to someone in regards of where the problem might lie. I do own an L&R cleaning machine but have not cleaned or oiled the watch for a year. It was just that the sound sounded unique. I'll see what happens when I put in the new main spring. Thanks
Anilv- Yes, I 3d printed the movement holder. The hard part was making a new stem that would lock in as the original watch was spring loaded to wind or change the time.
Most of us here do this for fun. A timegrapher is an essential tool, fortunately it's not expensive neither in physical or application form, much cheaper than a vintage cleaning machine, but much more useful.
Not knowing your experience and skills I suggested that you bring it to a competent person to avoid the possibility of ruining something that seems you care for. Of course if you know how to work on a movement yourself that's even better. I also love working on cars and motorbikes (was a professional when younger) but found that watch work is much more difficult than anything else, at least under the manual dexterity aspect.
JDM- Sorry, I wasn't trying to be difficult but there is something about watchmakers, ask for golf advice- a million answers, home repair- too many opinions. Go on a forum for watch repair and the answer usually is "take it to a watchmaker". A friend of mine actually is a watchmaker for Audemars Piguet and he doesn't work on anything old, he thinks they are "too finicky", in my opinion he is more of a technician, he just replaces components or parts, he doesn't really repair anything. If I didn't have a family to support I would consider going to Horology school just because I like it.
I certainly agree that working on a watch movement is a unique skill, maybe I'll think about buying a timegrapher.
Thanks, Rauld
Thanks, Rauld
Hi Rauld, This is an excellent forum and I agree that there is little help outside of it these days. The "trade" tries hard to keep repairs and knowledge for themselves and can be even rude to amateur hobbyists and Jobbers like myself at times. I received a lot of part time training as a young lad many years ago from a Vacheron trained watchmaker friend and it has stood me in good stead for the small amount of repairs that I carry out. This, WRT, and de Carles and Fried`s books for reference is the way I go. Best regards, Mike. (ecodec)
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
