Seiko 6349a weird seconds hand fault
Hi all, I have this seiko that I got as a non runner, I stripped it cleaned it serviced it and fitted a new mainspring and put it on an auto watchwinder and it ran ok for two weeks. I took it off and wore it then it started gaining time like 20 mins in a couple of hours and I have noticed that about every 10 to 20 seconds the seconds hand has a little spurt and suddenly moves on by 2-3 seconds hence the gaining time. I have never come across this before so any ideas as to the cause. Thank you in advance Tony
Does the 'spurt' occur at regular intervals?  It could be wheels binding due to a bent pinion.  I would look closely at the interaction if the pallet fork and escape wheel.
Anilv
Anilv
it seems to be as i say anytime between 10and 20 secs you get the little spurt of 2 to 3 secs, i think i will have to take it apart again and check the pinions.
4 hours ago, jdm said:
I can't know what is wrong with the mov.t but incidentally let me note that (at least) the dial fakeness sticks out.
i know the dial has been refinished the seller listed it as a repainted dial and i could see that anyway but i liked it so i bought it.
I usually remove the balance, give the mainspring a wind and see if the pallet fork snaps from side to side when helped with a oiler. Then I remove the pallet fork and check if the wheels spin true with no wobble. You can also observe endshake as well.
If the watch is very dirty a dunk in lighter fluid for a few minutes will help loosen the old oil. Remove day and date-wheels as well as any other plastic parts first.
The reason I do this first before cleaning is that sometime you find issues which render the watch not worth fixing unless you have parts. Nothing worse then cleaning a watch and then finding a fault which brings everything to a standstill!
Checking as you dismantle saves unnecessary work.
Anilv
Anilv
i am going to dismantle it again and check it a bit at a time, thanks for the tips.
tony
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it all worked perfect 🙂 I'm very happy how this worked for me 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
