What is wrong with this movement
oldhippy
They had clocks in railway signal boxes?
I used to work for the railway in Western Australia in the comms section in all the archival books and diagrams I had access to I never saw a clock in a signalbox.
Other than a bent crutch which is not really a problem I don't know what is wrong
I do not know Kay & Co LTD so I looked them up to find out they were primarily a mail order company but did indeed win a contract to supply GWR clocks.
http://91.197.228.188/~kaysh/2017/03/16/kays-watches-and-clocks/
The fusee and barrel arbours stick too far out of the back plate they are not rounded or polished at the ends and most of the English fusee clocks I've seen would have brass washers where the screws go into the pillars to hold the plates together.
Then you are correct. The whole clock is one big fake. It was made in India, its about 15 years old, it has been aged to make it look old.  I thought the poor so-called stamp engraving and the shocking finish would have told members that no way could it be an English movement.
As the saying goes down here where I live. Its as rough as a badgers ass. :D
Like the other thread about Chinese carriages clocks, the Indians seem to specialise in fusee wall clocks and Ebay is full of them popular clocks faked by the Indians are R.A.F wall clocks and Railway clocks one of the big give aways with these clocks without having to see the movement is that they are hinged on the left hand side of the Bezel instead of the right.
I've seen plenty of fake RAF clocks but this is the first time I've heard about fake railway clocks.
Do you have a picture of what a genuine Kay & Co clock movement looks like/
When I was looking up the company yesterday I could only find pictures of the clocks showing the dial and case.
24 minutes ago, Lenj said:
Do you remember this one on Ebay?? they were a wash with these, does anyone know why? Probably obvious..Anyone remember the serial number the same on every clock..lol
Len
I would be suspicious right away. The hands are the wrong colour, the writing on the dial is not right it is not in line with 12, so I would say it’s a new dial. Hinged to the left.
Yep correct and NO Cillet Bland it was Gillet Bland..All have the same movement number and these are stamped 6472 LONDON, other characteristics are very thick glass in the cast brass bezel which normally is hinged to the left hand side....I feel that they were trying to tell us, that all their clocks were fake..
Len
Based on what I learnt on this thread I decided to play 'Spot the modern fake' with Fusee clocks.
I came up with 3 that are obviously modern (last 20 or 30 years) fusee clocks made to look older.
I kept each one open in a new tab as I searched through ebay. AT the end I noticed all 3 clocks are from the same seller.
The seller does not state any of them are old and on the RAF sector clock he does state ' Not a wartime original.' So I am not saying the seller is doing anything wrong, but providing the listings just so other people can see more examples of modern fusee clocks made to look older. Although the fact he has 3 fusee clocks all with the same movements in them and different dials and does not mention anything on the clock that has GWR on it that is not original but does on the RAF clock is a bit odd.
Note the are all hinged from the left, have solid pillars with no turning on them and wire instead of chain or cat gut and the finish on some parts are average. Not to mention to me all 3 of the dials just didn't look right.
https://www.ebay.co.uk/itm/Fusee-10-Inch-Dial-Clock/232804820013?hash=item36343fa42d:g:8ugAAOSwQQlbITNS
https://www.ebay.co.uk/itm/8-Inch-Dial-Fusee-RAF-Sector-Dial-Clock/332679578519?hash=item4d753f8397:g:pnMAAOSwnvVbGowW
https://www.ebay.co.uk/itm/Fusee-12-Inch-Dial-Clock/332632724560?hash=item4d72749450:g:F4UAAOSwFWda4cMa
On ‎18‎/‎06‎/‎2018 at 2:28 PM, Tmuir said:
But wait he has more.
I could be wrong but I think this LMS clock may not be original.
https://www.ebay.co.uk/itm/Fusee-12-Inch-Dial-Clock/232798691876?hash=item3633e22224:g:mA8AAOSwbbRbGoyg
:D
Now this is genuine lol, just look at the hand painted dial, must be all of 3 weeks old, my granddaughter could make a better job of that..
I just noticed another tell tail sign when I went back to look at the 'LMS' clock for a giggle. It has philips heads screws used in the clock case. If it was a genuine clock all screws would be fkat head screws not philips heads.
The pendulum rating nut is also wrong.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
