What is wrong with this movement
oldhippy
They had clocks in railway signal boxes?
I used to work for the railway in Western Australia in the comms section in all the archival books and diagrams I had access to I never saw a clock in a signalbox.
Other than a bent crutch which is not really a problem I don't know what is wrong
I do not know Kay & Co LTD so I looked them up to find out they were primarily a mail order company but did indeed win a contract to supply GWR clocks.
http://91.197.228.188/~kaysh/2017/03/16/kays-watches-and-clocks/
The fusee and barrel arbours stick too far out of the back plate they are not rounded or polished at the ends and most of the English fusee clocks I've seen would have brass washers where the screws go into the pillars to hold the plates together.
Then you are correct. The whole clock is one big fake. It was made in India, its about 15 years old, it has been aged to make it look old.  I thought the poor so-called stamp engraving and the shocking finish would have told members that no way could it be an English movement.
As the saying goes down here where I live. Its as rough as a badgers ass. :D
Like the other thread about Chinese carriages clocks, the Indians seem to specialise in fusee wall clocks and Ebay is full of them popular clocks faked by the Indians are R.A.F wall clocks and Railway clocks one of the big give aways with these clocks without having to see the movement is that they are hinged on the left hand side of the Bezel instead of the right.
I've seen plenty of fake RAF clocks but this is the first time I've heard about fake railway clocks.
Do you have a picture of what a genuine Kay & Co clock movement looks like/
When I was looking up the company yesterday I could only find pictures of the clocks showing the dial and case.
24 minutes ago, Lenj said:
Do you remember this one on Ebay?? they were a wash with these, does anyone know why? Probably obvious..Anyone remember the serial number the same on every clock..lol
Len
I would be suspicious right away. The hands are the wrong colour, the writing on the dial is not right it is not in line with 12, so I would say it’s a new dial. Hinged to the left.
Yep correct and NO Cillet Bland it was Gillet Bland..All have the same movement number and these are stamped 6472 LONDON, other characteristics are very thick glass in the cast brass bezel which normally is hinged to the left hand side....I feel that they were trying to tell us, that all their clocks were fake..
Len
Based on what I learnt on this thread I decided to play 'Spot the modern fake' with Fusee clocks.
I came up with 3 that are obviously modern (last 20 or 30 years) fusee clocks made to look older.
I kept each one open in a new tab as I searched through ebay. AT the end I noticed all 3 clocks are from the same seller.
The seller does not state any of them are old and on the RAF sector clock he does state ' Not a wartime original.' So I am not saying the seller is doing anything wrong, but providing the listings just so other people can see more examples of modern fusee clocks made to look older. Although the fact he has 3 fusee clocks all with the same movements in them and different dials and does not mention anything on the clock that has GWR on it that is not original but does on the RAF clock is a bit odd.
Note the are all hinged from the left, have solid pillars with no turning on them and wire instead of chain or cat gut and the finish on some parts are average. Not to mention to me all 3 of the dials just didn't look right.
https://www.ebay.co.uk/itm/Fusee-10-Inch-Dial-Clock/232804820013?hash=item36343fa42d:g:8ugAAOSwQQlbITNS
https://www.ebay.co.uk/itm/8-Inch-Dial-Fusee-RAF-Sector-Dial-Clock/332679578519?hash=item4d753f8397:g:pnMAAOSwnvVbGowW
https://www.ebay.co.uk/itm/Fusee-12-Inch-Dial-Clock/332632724560?hash=item4d72749450:g:F4UAAOSwFWda4cMa
On ‎18‎/‎06‎/‎2018 at 2:28 PM, Tmuir said:
But wait he has more.
I could be wrong but I think this LMS clock may not be original.
https://www.ebay.co.uk/itm/Fusee-12-Inch-Dial-Clock/232798691876?hash=item3633e22224:g:mA8AAOSwbbRbGoyg
:D
Now this is genuine lol, just look at the hand painted dial, must be all of 3 weeks old, my granddaughter could make a better job of that..
I just noticed another tell tail sign when I went back to look at the 'LMS' clock for a giggle. It has philips heads screws used in the clock case. If it was a genuine clock all screws would be fkat head screws not philips heads.
The pendulum rating nut is also wrong.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
