What is wrong with this.
oldhippy
The clock is much later than the 1860 Stated by the seller, it has a modern replacement escapement, the top of the clock although the correct style is not original to the clock it is a different colour to the rest of the clock, the case may be bronze but the top is brass.
The movement is modern the hands would not be push fit for a old clock they would be held by a hand collet and pin on a period clock
Its a bit of a marriage of parts looking at it.
wls1971. You have the two right answers. Replacement platform. The whole case is in fact brass and not bronze. Peanut goes to you. :D
You are wrong about the date. The movement is around1860. The push on hands are correct and are matching, the style is spade.
A big thanks to all for taking part. Next time I will have to make it harder.
I was more wrong than right, how would you know if a case is bronze as opposed to brass what would be the tell tale signs of a bronze case ? I am currently reading carriage clocks by Charles Allix and Peter Bonnert I shall have to study some more I have a lot to learn.
A picture would be the colour. If you had it to handle it would be the weight. Solid  bronze would be much heavier.
English Giant c/clocks that have the case made of bronze are a hell of a weight. I used to wonder why are they called c/clocks its because of their style. A petite lady would have trouble lifting one.
12 minutes ago, omx5o said:
You can learn a lot from these quizzes.
I was going to say that the key was missing. Not a major problem though.
I am glad you enjoy them. The key is an important item. Very valuable clocks that have their original key can add to their price. While we are still on the subject of C/Clocks the original travel case can also add to their value, so can the original glass panels.
Any part of a clock that needs to be replaced should be catalogued for the customer,  the old piece handed back. It is also a good idea to tell the owner to keep the old parts with the clock.
32 minutes ago, clockboy said:
Got me. However I did notice the hairspring seems to be sitting out of centre so I doubt if it is running that well.
I thought it looked pretty sick when you consider it’s a new platform.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
