Unitas 6497 shock spring replacement
20 minutes ago, PeterS said:
When I was releasing the shock spring on the balance it popped out. I found it but after an hour of trying to get it back in it snapped.
I found an assortment of shock springs here:
https://www.cousinsuk.com/product/shockproof-springs-wristwatch
What are the chances of the U shaped spring being there and how do I fit it in?
Sounds like it's a kif spring you could have there? Or is it a incabloc spring. Top or bottom?
38 minutes ago, PeterS said:
It's incabloc, top I think (not the dial side), I found this image
That could be a little tricky. You probably need to remove the regulator arm to get that in.  Or at least the arrow pointing backwards. Inked6497.JPG.546e8803e13d1412cee0d9479c9e39be_LI.jpg.adeeb42f937db7f4d8545af8054b611b.jpg
Edited by rogart63
Thank you for letting me know. It looks like I will have to get a new movement. I only started the course level 2 and that might be beyond my abilities at this moment.
5 minutes ago, PeterS said:
Yes, that's the one
Well, that’s why the spring came out. It’s not your fault; it’s because it’s one of the aspects which the failed to copy properly. They can be carefully reinserted, but that’s regarding the original Chinese part. The way to avoid them falling out is to ensure they lift and drop perpendicular to the movement. If they angle then they pop out entirely. The Swiss ones are easy.
You may be best finding Chinese spares if that’s possible. I can offer some real incabloc springs, but they are all from 10 - 12 ligne watches, so not sure if they’d be a bit small.
I didn’t know they could fall out, I would have been more careful. Bummer!
You live and learn!
Thank you for the offer, much appreciated. I’ll get a new one and use this one for spares.
2 minutes ago, clockboy said:
The Units Cal 6497 shock springs spec.
upper shock size.  470.13
lower shock size. 476.03
Thank you clock boy.
Are they available to purchase somewhere and is it fairly easy to install them?
I can only find the assortment of shock springs at Cousins and have no idea whether the right one would be there and my feeling is I'd probably snap it again.
I'd rather fix it than buy a new one but luckily it's not that expensive to buy a new movement.
23 minutes ago, PeterS said:
Fingers crossed it will fit. I’ll give it a go.
Question is how to install it. I looked on YouTube and I found a video for kif spring but not for this one.
This is where it gets slightly complicated. The fact that the spring falls out on the Chinese movement proves that there is wiggle room for it to be fitted as-is. So, for the original spring, you carefully angle it back in place. If the new spring is of the same dimensions then the same will apply. If not, then you will have to disassemble the setting to fit it.
1 hour ago, PeterS said:
They look the same. Is it different size?
Well, I doubt anyone has measured them exactly, but if the spring was the correct size, and the slot in the setting where it hinges was the correct size...... then it wouldn’t fall apart in the first place!
This is where Rodico is your friend. Put a small piece just behind where you  want to drop the spring in. You can then stick the spring to the Rodico, and manoeuvre it straight, and get the right angle, before sliding it down in to place. I find sharpened pegwood sticks help.
Some will tell you to put it in with tweezers - but it's not easy. Replacing these springs is one of the things I struggled most with (apart from wrestling hairsprings of course !)
Also when opening the springs, If it looks a bit loose, I will use a bit of Rodico to to make sure it's not going to pop out of it's slot.
That’s an excellent tip. I was wondering whether I could use rodico in some way but couldn’t figure out how to use it so I used tweezers instead.
I’ll give it a go when the pack of 5 arrives next week – that’s if they fit the clone.
I think Rogart is right. I couldn’t fit it in. I’m not sure whether I’m doing it correctly but I cannot get it in no matter what I do.
I can hold the spring with tweezers, go parallel into the slot and try to turn it 90 degrees to install it. But it only turns say 70-80 degrees and I cannot turn it further.
I would say that the Swiss spring is larger, at least the hinge if not the whole spring.
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
