Hi, I'm working on this Ronda 217 movement and I couldn't figure out how to take the jewel off the balance cock. Are these designed to be disposable?
Any idea how to clean and oil it properly?
Thanks alot
I removed the balance wheel and cleaned and oil from the inside. Stupid construction. Same with the jewel in the bottom plate.
Edited by rogart63
Thanks alot
That's a new one for me. It looks like it could screw off. However if not you will have to clean buy soaking in a dish with a de-greasing fluid and then agitate with a blower. Then dry & then lube with a auto oiler.
Does the base plate have a conical pivot (and conical bearing) with adjustable endshake (by screwing the bearing in and out)?
No balance on the movement i had. But had a jewel like that in the movement plate. Couldn't remove it. Looked pressed in. So think you need to clean as is.
Thanks for the replies everyone.
I will try the unscrewing and see if its possible.
What I did is just clean in an ultrasonic and naphta and oiling it from inside which was very tricky because I couldn't figure out how to remove the hairspring from the balance cock.
I will look into it again.
Thanks alot
On 4/26/2018 at 11:39 AM, rogart63 said:
Have an old one here somewhere. Can  do some violent work on it and see how it sits together :)
That would be great if you could do it.
It's removable but i wouldn't do it. Found this balance so i took it apart. The jewel is one part . And there is no thread in there . In order to remove the balance i had to remove the arms . To clean just put complete part in ultrasonic bath. And oil the jewel from the inside.
DSC09671.thumb.JPG.786a01ac3ae5aacadcec8ebc61c39ac9.JPGDSC09670.thumb.JPG.cbade49aaaf8428cf02c62350a9305ea.JPGDSC09672.thumb.JPG.d2cb6048b606458561b0c87105a86452.JPGDSC09673.thumb.JPG.0aaf8a5cab24c57e6a39d93dbfedf300.JPG
Thank you Rogart63 for doing this. I'm gonna follow this procedure.
