Stubborn Bulova case back
Lc130
I've seen your link, but are you sure that's the same watch as yours? First of all,  If the back of your watch comes off, there would be NO ROOM for the dial+movement to come out as it would be a very small opening and obviously the dial would have to be attached to the movement. What does the front of the watch look like? Does it have a small dial and:huh: a large bezel?
J
I'm trying to open it on the side opposite the crown.  That's where the chewed up notch is.  I can't tell if that notch is machined or simply hacked in by others trying to open it.  The notch is seen on the second pic.
Thanks!
Charlie
Edited by Lc130
I would say it has a two-part stem and you have to remove the crystal to get the movement out through the front. That notch you've been trying was someone's wishful thinking. The stem should pull out completely--use a pair of tweezers or watch hand removers with low to moderate force. You'll need a crystal remover for the next step.
J
OK, I was able to open a seam in the back using a razor.  The back definitely comes off.  I can just barely get a Horotec case knife in and can see the seam open and close when I rock the blade.  It wont pop off.  Is there some penetrating solution I should try?
Thank you
Charlie
Some criminal "repairers" glue the back to make sure the customer comes back to them in desperation. Apply no more than 2 or 3 drops of acetone (nail varnish remover) to the seam. However most likely that's not needed, just go around the seam slowly and patiently with a small blade, max 5mm wide. Don't twist, just pry it up. That will minimize marks on the case.
Thank you
Charlie
Wow you found it.... that back must be glued on like @jdm said. If acetone won't work maybe isopropyl alcohol?
Realizing I'm a beginner, I took it to the watch guy at the mall who popped it off in 2 minutes.  Though with much effort.  All that fighting get the balance swinging again to boot!
Thank all very much!
Edited by Lc130
  • 3 years later...
I have this exact same watch and am having the same issue getting the back off. The watch came from a watchmakers estate and has been sitting in a drawer since the 70's so I don't think it would be glued on, I just think this case is a real bear to open.
I've tried my case knife as well as one of these snapback case openers that I have successfully previously used on stubborn cases, but it's only dinging up the case and ruining the blade on the case opener.  The stem is loose on this watch and it's not a split stem and the watch won't come out the front after removing the crystal so I'm not sure what to try next. I guess I'll give a razor a try as well.
This is the same watch after disassembly.
Edited by GuyMontag
I came back to this watch today and when I looked at the caseback seam under a scope I could see there *was* a lip where a case knife would fit but when the last person who worked on the watch put the caseback on they put the lip underneath the lug, which is curved towards the caseback. That made it difficult to get access to as the lug was in the way, but I was able to get a razor blade in the lip and pop the caseback off.
Small victories are what life is about!
    • Hello and welcome from Leeds.
    • I don't want email notifications, but I'm not getting the bell notifications. Ha ha, and then I get one about your message @GuyMontag
    • Hello forum, I have just joined the forum and I believe it is the done thing to introduce myself.  I am based in Surrey UK and am essentially a complete novice at watch repair.  Fairly life long interest in watches, starting from not being allowed one as a child as I kept taking them apart… After watching a you tube video of a watch service, I thought to myself “I could do that…”. Well I got myself a Seiko 7002 dive watch that was a non runner. Striped cleaned and reassembled. With much blaming of tools, dropped parts and feeling out of my depth I got it working again. I built my own pressure tester and it leaked like a sieve! fixed now though.    I’ve since done a few 7002’s and an NH35A with mostly success. But now I’m left with quite a few working movements and no budget for cases. Overall my lack of a timegrapher has really hampered things and efforts using phone apps have been disappointing.    I next moved to an ETA 2472, all went well until I snapped the stem after failure to find a suitable case for it. Alas replacements seem almost the price I paid for the movement! Hopefully I’ll stumble on a suitable one one day.   Currently working on a Smiths 512 pin pallet movement. All went well until the shock protection. My goodness they are tricky compared to all the others and now I’m down one shock spring. This was my first movement I’d done with no video or walkthrough or even manual for backup. So I was pretty pleased with my self, briefly.  Well, that’s me and my watch repair journey.    Rob
