I never knew
This is the best option - if you have a lathe. For those of us without, I use a Balance Staff Remover as shown in your pic. Using this, I have not seen any damage to a balance. Rolex recommend just pushing it out as their balance arms are quite hard. But, as @Klassiker suggests, do a search of the forum and you will find plenty of discussion.
This has been discussed in great detail several times already. All of the methods you mention carry some level of risk. If you search for @praezis posts on the subject, you can find convincing arguments why cutting off the hub (not the rivet) is the safest method.
I'd thought the same along with the fact that they'd already stated the train ran without the balance?
