I never knew
Just checking terminology here. When a pivot is described as having a certain height is that measured from pivot tip to pivot tip or from the face of the wheel to the tip of the extended pivot? I have a bit of a strange one that measures closer from tip to tip but not from the wheel face to tip (I get 3.1mm from face to tip and about 3.6mm tip to tip when badly measured with my Vernier calipers)
This is the best option - if you have a lathe. For those of us without, I use a Balance Staff Remover as shown in your pic. Using this, I have not seen any damage to a balance. Rolex recommend just pushing it out as their balance arms are quite hard. But, as @Klassiker suggests, do a search of the forum and you will find plenty of discussion.
This has been discussed in great detail several times already. All of the methods you mention carry some level of risk. If you search for @praezis posts on the subject, you can find convincing arguments why cutting off the hub (not the rivet) is the safest method.
