Pocket Watch and Jeans
That's another interesting solution. Thanks for that. Aren't the Elgin staffs specifically designed to be a friction fit rather than riveted?
By nickelsilver · Posted
The pushing out method in modern times comes from Rolex, and they have specifically made staffs to accommodate it. I believe Elgin did something similar in the past. If you don't have a lathe, then a Platax or something like the K&D tool that holds the balance arms firmly down is the best. Still a risk of opening the hole. If you have a monometallic balance (no steel) you can soak in a saturated solution if aluminum to dissolve the staff. This won't harm the balance, and is preferable to punching out. -
The same tool will work on all sizes of balance. You sit the staff in the correct size hole in the staking set base. The tool them clamps the balance arms, and then the punch pushes the staff out.
That's just it. I am actually looking to see if I can replace the second wheel on a Omega 3220 which uses the ETA 2892-A2 as it's base. The 3220 actually has a push fit chronograph driving wheel on the pivot rather than a second hand. Not certain that this would be a direct replacement but it could be worth a shot versus paying $150AUD for the Omega part.
Yes, being lathe deprived is a problem that I have, so obviously interested in solutions that don't require one. The Balance Staff removers are interesting. I wasn't sure if you could get them in a size to suit a typical wristwatch movement, I thought they were more suited for pocket watch balances. I was surprised to see a staff just pushed out with a Horia tool but I guess if you get a very close fitting stump it would potentially do the same amount of damage as a remover (the only difference being that the remover seems to clamp down the cross arms of the balance immediately surrounding the staff). I did read somewhere that Rolex (who apparently recommend this) balance wheels are harder than others. This is maybe one to try on already scrap balance.
