Hardening Screwdriver Blade
jdrichard
I made a screwdriver blade or of a rod of steel and am having a very hard time hardening it. It is part of a set of 6 and is the smallest blade. How do I get this blade hard. I do have a torch and have tried heating it to red and dunking it in water. Still ends up soft.0dee7afffb89315d40cca17c6bfee488.jpg03cefc3e71d385d912f604fa94cc97c0.jpg54c76d81b671195ad3d37724df41b690.jpg87acb6c38ab8cb1ed78bc7ed958de9dd.jpg
Its my understanding that its all about carbon content and heat. Red hot isn't a temperature as such, only an indication of it. There are tons of opinions and methods described online about heat treating and hardening steel, so I'd check google. Also the type of steel, ie carbon content is critical also. It might be best to start with something like drill rod that is made for hardening such as what you're looking to do...just my opinion, your mileage may vary :)
Yes, first question is, what composition? Needs to be high carbon steel.
Cherry-red for a minute and immediately dunk. Now drag across a sharp file, and if it has succeeded in becoming glass-hard, then the file will not bite.
Temper to somewhere between brown and blue.
that's called mystery metal, for use when its required that the steel rusts and sinks.  Regular mild steel, ie 1018 does not have enough carbon to be heat treated.   Remember all that talk about drill rod?  Get some O1,  heat to bright red (in sunlight) use an oil quench and then temper and you will be off to the races
Edited by measuretwice
An easy test to see if it has enough carbon in it to harden is the 'spark test.
Its not fool proof but it will definitely let you know if its not carbon steel.
If you have a grinder just grind a bit of it and watch the sparks, carbon steel will have sparks explode off the sparks like little fireworks, mild still will have just straight sparks, look here for a better explanation
https://en.wikipedia.org/wiki/Spark_testing.
Big thanks. Going to try this.
I remember once trying to make one of the round clock hand pullers using a small offcut of some GI water pipe thinking it would be easy to machine true. It was horrible my cutters either dug into it and pulled it off my lathe chuck or just chattered terribly, ended up chucking it in the bin.
The wonders of 'Mystery metals'
4 hours ago, jdrichard said:
And this steel was not easy to cut, even with a carbide graver blade. Need to source tool steel
Sent from my GT-N5110 using Tapatalk
Try using an old drill bit and a dremel, you won't be able to cut it with a graver, but it's sure to be hard enough. Chuck the bit into the lathe, then use the dremel to rough it down while turning it, then finish with a stone. Stone the tip when done. You may have to anneal slightly so it won't be too brittle.
I actually used this technique on the bit I made. Dremel with a grinding wheel and you turn the part on the lathe. Takes material off fast. Then I did use a stone with oil for the finish. I have plenty of old drill bits. Thanks.
I am going to pick up some O1. Drill bits seem to be a bit thin in the drilling area to have enough material to build the bit
I actually mount my dremel to my cross slide on my sherline lathe. Using a cut-off wheel and small increments works like a charm on harder steel, just have to let the wheel do the work and not advance the feed too fast or the wheel will snap.
That may not work on my watchmakers lathes
Grab some silver steel rod. Or anneal some blue steel. You want a carbon content of around 1%. It’s cheap and handy to have knocking about for making tool parts.
Oddly, I can’t see any for sale on the Canadian ebay, apart from stuff from the Far East. I’d be slightly hesitant to buy stuff from there to be honest. Allegedly, a lot of the Sheffield steel rod which we buy in the UK is often old stock, and sometimes made by Stubs. I can post you some if you get stuck finding any.
I do have some blue steel. I think i will pick up some drill rod today.
    • I would use some binding wire around the part before heating it. It protects the steel from being burned. I know that sounds strange, as you're going to heat it with a blowtorch, but if a part is thin and delicate the steel can literally burn away before your eyes, which isn't funny if you've put hours into the job. I bought some tools steel from Cousins a few years ago which turned out not to be tool steel, because it couldn't be hardened or tempered. I wasn't impressed, as I had spent two hours making the part for it to be useless.
    • Hi that’s what was meant by animal glue “ a glue made from animal products”. Ie bone , skin and other animal residues.  There was a place at Huntington YORK who used to boil down the ingredients. It stunk.   We used it in pellet form in a sort of Bain Marie on a gas ring  it was very good, didn’t think it was around any more with the modern glues,
    • It's back to the drawing board I'm afraid. As pointed out, the Rodico trick is so fiddly and my pin vice jaws don't close in union. I tried but the screw is so small it's hard to grip the screw in the Rodico without it moving all over the place while trying to get it in the vice. I started to shake too much so gave up before the screw flew off somewhere never to be found again.  I'm now thinking that maybe I could bond the screw on the end of a bit of peg wood and then dissolve the adhesive afterward.  I just had another thought🤔 I have some really small PCB drill bits maybe I could drill a small hole in peg wood and push the screw in, as stated I only need to get the screw started.  Another idea 🤣 Magnetize the screwdriver to hold the screw 🤔
    • Yeah there is a spring under there. Hopefully now I can source a screw for the click and the bridges! Thanks for your help!
    • Definitely worthwhile, if you are working with old watches - just be sure it's an actual Geiger counter, not one of the vast range of scam/fake "Radiation detectors" on ebay & amazon etc. that detect RF or static electricity...   In the mean time, I'd put the dial and hands in zip bags & wipe down the work area with a damp cloth to pick up any dust, then discard the cloth. The emitted radiation from radium lume is not normally harmful - but inhaling or ingesting a single particle of the material can cause serious long term harm, so do take care with it.
