You know how it is, its late at night, you have had a couple of whiskeys you are browsing ebay and you see something, you place an impulse bid and wake up in the morning to find you have won it.....
ACtually quite pleased, its a bit rough but price was good, hopefully when it arrives it will be in a state worth restoring.
I like military clocks, I've got a couple of Russian MIG clocks, a Russian Tank Clock, an American Seth Thomas Navy Deck clock and now a Waltham aircraft clock.
Just need to get myself some British ones now....
It will be a couple of weeks before it arrives, but there are a couple of taster photos of it on ebay.
No idea of its exact age yet other than it cant be later than the 1950s, but if I am lucky will be of WWII vintage
https://www.ebay.com.au/itm/VINTAGE-WALTHAM-8-DAY-A-11-MILITARY-AIRCRAFT-AVIATION-CLOCK-/382333164905?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=oZxjZV%2BqZEhnkGjEDMhqfs0Js7M%3D&orig_cvip=true&rt=nc
good show.  had any ships clocks apart?  Vinn
Customs is not an issue...yet,
At the moment if it is under $1000 Aud including postage there are not import fees in Australia though the government wants to change that.
Price was low enough if it turns out to be a junker it will be a good one for me to practice on as I've not worked on an aircraft clock before.
I just can't help myself.
Was trawling ebay again and found an Elgin Pioneer aircraft clock for sale in Australia.
I do know this model of clock was used in some Australian made aircraft and what was very interesting about this clock is it has scratched on the back of it A20-343, this is the service number for a Wirraway Aircraft that was made during the war in Australia.
Only 15 Wirraway aircraft still survive out of the 755 built.
I've not managed to confirm that this model of clocks were used on Wirraways yet, but if so its very exciting.
Anyhow enjoy a couple of photos of it, it is not working and judging by the rust on the screws it could be in a bad state, but we will see.
  • 7 months later...
I posted in the clock forum but I'm excited I found this thread again as this is what led me to the site to begin with!
My clock looks very similar to your aircraft clock. Do you know if this one is also an aircraft clock? Thanks in advance for your help!
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
