The begining
Orville
I might have chimed in before but I could not find the post if I did.  So, in keeping with my normal watch practice, I'll do it again.
I'm in Tijuana Mexico, almost retired and decided to learn about the 30 or so watches I have because they, like me, are getting old.
Watched all of Kevin's videos which inspired me to go for it.  I've spent more time on my knees her than I am sure the Pope has at the Vatican.
I am self learning on a simple and inexpensive movement, the Elgin 554.  So I bought up a bunch of them.  They helped a lot.  My weakness is in handling the balance and I have a lot of microminiature scouring pads to prove it.
So I decided to focus on hairsprings and hairspring manipulation in order to be able to deal with hairspring issues when they arise.  I figure I'll spend a year on that.  In the meantime I will, of course, work on the Elgin movements in order to clean up things like getting the tweezers handling right, learning all about screwdrivers etc.  I've replaced balance staffs and reinstalled balances and put the watches back together, but I must learn everything there is to know about hairsprings.
Learning how to use the tools has been a major part of learning to work on the watches.  The right tools for the right job, handling screws so you're not chasing them down the street, all that is vital.  So I have a long road ahead and a lot of watches to service.
Thanks to Kevin and thanks to all of you for being so kind and so giving of your experience.  Micromechanics is a whole new universe.  A great place to lose yourself in.
Hi Orville and welcome. You are doing very well and working very constructively. For the hair spring study obtain a copy of Donald de Carles "Practical Watch Repairing."  It is an excellent and comprehensive study in my opinion and that of many others. It  well covers hairsprings  in theory and practice  and the Breguet overcoil hairspring also. Split balances and monometal balances are detailed  Figures for steel and Invar, Elinvar and Beryllium are  also covered.  I feel sure you will enjoy watch repairing and there are are a lot of very experienced and helpful people on this site. All good wishes, Mike. UK.
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
