Seiko 7S26A problem
Chopin
I received a 7S26A a few days ago and it was supposed to be running but when I got it it wasn't and there was a small issue with the stem/calendar changing and I said I was going to service it anyway so I didn't test it.
I stripped it all apart, and put it back together, but when I finally installed the hairspring the movement is not starting.
If I remove the hairspring and the pallet and touch lightly some of the gears, if the spring is loaded, it will start running and the hands will turn and so on. With the pallet on, if I move it left and right it seems to put in motion all the right wheels but when I install the hairspring it just won't start.
I've checked the hairspring as well as the other parts and nothing seems damaged at all.
(yes, the parts have been lubricated accordingly)
One thing that I found a little strange is the fact that with the hairspring on, if I rotate it around with the tweezers there seems to be some resistance/friction and it's not smooth easy turning. It won't return to its position unless I create more tension on the hairspring by rotating it.
Edited by Chopin
At first I thought that I didn't install it right and I kept trying but I'm pretty sure that it is.
I do know that when you don't install it correctly you can't rotate it completely on one of the sides (depending on the position of the pallet horns), right ?
You described that there is a balance endplay issue, as in lack of it. With the pallet removed the balance (not the hairsping), will not oscillate. It can be bent pivots. even a tiny amount is enough. Also check that end stones are not installed upside down.
Edited by jdm
When the watch is charged, if I remove the hairspring balance and pallet and move the wheels a bit, it starts to function until the mainspring discharges.
I know that.The pallet was always there. When the hairspring balance would be installed so was the pallet so that I can check the entire functionality of the movement.
The pivot seems fine at first glance. I'll check for more details tomorrow when I have good lighting. I badly need a LED lamp...hehe.
I think I will try and install the balance without the pivot and see if there's still any friction...
Edited by Chopin
Small update: I have installed just the balance, without the pallet fork, and everything seems alright so now I'll have to focus on the pallet fork... I do have a few but not sure if I have the one with the same dimensions as this one...
I'll have to check it out and try and see if I can find any damage... I checked it out before and I didn't see anything wrong...
7005 and 7009 and such will fit i think. You will have to take a look at the parts to get the Seiko number and see if they would work. Not always you can see if the pallet fork is okay. Have seen those that look okay but still doesn't work in the movement.
At some point I noticed that one of the jewels from the pallet had become slightly disengaged from it's orifice but I straightened it without any issues (it seemed to go slightly under the escapement wheel and thus wouldn't fully engage). Even so they both look fine and everything seems evened out.
You mention the watch was a non-runner. So the watch may of already been played with. With some tension on the mainspring and the gears are running freely, with the pallet fork installed, rocking it side to side and the escapement wheel is rotating, the stones are fine.
You need to ensure the balance impulse jewel aligns centre to the banking pins. You can either remove the train bridge and check visually or play with the etachron adjustment to see if there's any sign of life. But...
From what you've described I tend to agree with Jdm. Most likely a bent pivot or end-shake issue.
Sent from my SM-T585 using Tapatalk
Check
1. Hairspring is in between regulator pins. The earlier 7s26 (ans 7s36) had a habit of the hairspring getting dislodged.
2. Correct screw used for pallet cock. Yhe correct one has a shallow/thin head. If wrong screw used it can rub on the balance.
Hope you find the problem!
Anilv
That is an alleged defect of the B version only, but OP has A version, which also has no "Etachron". However, all run (poorly) even with the HS dislodged from the regulator.
Well, you're not going to believe this. I feel so embarrassed.
Apparently the second hand bent slightly and pressed against the minute hand and that is why the movement was not starting. I sorted out the hands just before going to bed and now I reinstalled the pallet fork and hairspring and it all works.
Bonus question: the oscillating weight seems to be a bit wobbly. I think the ball bearings are loosened or something like that. It makes a bit of noise and if pressed downwards it touches the metal plates beneath slightly.
Can the ball bearing for this movement's rotor be replaced ? I noticed that some are press fit and they just get replaced.
Also, apparently the screws that I used for the pallet bridge might be incorrect as it seems to work fine without the screws in place. Either they were never right or I used them up someplace else in the movement. Not sure if possible but oh well...
Ooops about the second hand[emoji16] And if wrong screws used on the pallet fork bridge and they're not flush, as "Anilv " pointed out can cause issues. If screws are being mixed up, you can always screw back in whilst stripping the movement down. I like to use multiple dishes.
1. Balance and pallet.
2. Motion works.
3. Barrel bridge etc.
4. Train .
5. Keyless works.
Looks like your Rotor has worn. Common problem. Not from any weakness in design from Seiko but years of neglect and correct maintanance. I don't believe bearings can be serviced, so if the autowind is failing, a replacement will be required.
As a footnote hope you serviced the mainspring. I know Seiko recommend changing the barrel but people often neglect the spring and wonder why they have a low amplitude or the watch isn't performing or breakage occurs.
See pic, this movement is younger than yours, even so, it's totally dried up. Also note being Japanese, chances are it's a "Lefty"4ff5f81543246faf5a48f96ef145c775.jpg
I don't understand how the hands became intertwined as I handle my movements very carefully and it was always sat on a movement holder. They are not the original ones but modded ones and they seem to be inferior in quality to be honest.
I have my part dishes/organizer on order but still waiting for it to arrive, sadly.
One other particularity of the movement is that in some angles it seems to stop, I think. If I wiggle it a bit it'll restart. It kind of seems as if the hairspring is weak, so to speak. Is it possible that it's misaligned (I'm talking about the 2 regulating tabs)?
Did not check the mainspring, yet but I might do that.
Edited by Chopin
Without pictures one can't tell about HS, however being "weak" is not enough for it too stop. First and foremost you have to check pattern and amplitude on the timegrapher. I don't know what are the "regulating tabs" you're talking about, 7S26A doesn't have any.
Aftermarket hands are pretty useless.  While I have used them it's only as a last resort.
The rotor bearing is pressed in and should be replaceable but as the part is not available separately you would need to source a complete rotor assembly. On older watches they can be pressed in and replaced but I only do that if I want to retain the auto-wind bridge, like in this 6105 diver (also with crap aftermarket hands) in the link below.
rgds
Anilv
5 minutes ago, anilv said:
The rotor bearing is pressed in and should be replaceable but as the part is not available separately you would need to source a complete rotor.
As mentioned above rotor bearing it is not replaceable on on the 7S26, and there is no P/N for it. Some people have tried swapping it anyway, and it hasn't worked.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
