Happy New Year. My first job of the new year is to add a stem extender to a watch. I had to buy three to get one and I am curious to see photos of how one should keep parts organized and more importantly how to easily determine if I have the "widget" or do I need to order one.
Thanks very much indeed
Todd
  • 1 year later...
Hi. as a first timer this is how I do it. I keep the tops from milk cartons, wash them and use as in photo. Keep any screws with the part.
Incidentally, if I get the correct replacement quartz movement for this watch I will post details on the forum. Also, if you have a camera that is good at close-ups, take photos of everything as you disassemble it. Happy New Year to all contributors.
Todd
Sorry, I would be a bit too embarrassed to photograph my parts storage at the moment. It's really all over the place. But much of my stuff is in trays similar to these:
https://www.cousinsuk.com/product/compartment-boxes-with-divides-slide-lid?code=B39605
I have a lot of these as they are larger than normal so I find them easier when searching for that vital bit. I purchase from Axminster Tools & machinery .
Edited by clockboy
I went the cheapskate route and bought an 8 pack of 6cm x 6cm plastic sauce containers with clip on lids (purple, bleurgh) from my local 99p store.
For larger items ie straps & bracelets, a 3 pack of 6.5cm x 9cm hermetic clip lid boxes.
Nice ideas here. I use the same as Geo, Mark and ro63rto and I'm looking to order the oversize tins clockboy posted. All very handy depending on what to store.
hi mr beebe, this is where most of my parts are stored, the place where the chair stands on, last count 15 bridge screws 3 click springs and a couple of winding dogspost-618-0-39538200-1421249191_thumb.jpg
i use these which are quite cheep on the net and at 30mm you can put most movements in thempost-618-0-07993700-1421249389_thumb.jpg
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
