Patek question
Phillip
I am a retired jeweler, not a watchmaker, so forgive me if I don’t speak the correct language.
A friend asked me to look at this little old Patek, which runs, drives the minute hand, but neither drives nor sets the hour hand. There are broken teeth on both the ‘barrel gear’(?) which engages in the setting mode, and also on the wheel that delivers power to the hour hand wheel.
What to do? Does anyone fix watches this badly damaged? Does anyone have a trove of parts for these old watches? Does anyone make replacement parts?
grateful for advice
Phillip
Very difficult because of age and exclusivity of make. The first thing I would try to do if find what movement this is. I saw  ladies Patek on bidding site that is similar to this but has adjustments and 18 jewels--that one was from 1942.
J
I would say that the first part, the clutch, could be interchangeable with clutches from various other watches. The problem is that, perhaps, the only way to find that part is by having someone with a huge box of such clutches try them all out until you find the one with the same dimensions.
Same rule could apply to the 2nd part which I don't know what is named but not sure... It's harder to find a non-Patek replacement for that one, I guess...
Edited by Chopin
I guess an experienced watchmaker with a well equipped workshop could let some teeth into that damaged brass wheel. The clutch wheel would be more difficult repair but as Chopin says, might find a suitable alternative clutch wheel.
It all really depends on what the watch is worth. Are the case and dial in good condition?
Patek would doubtless charge thousands and only offer a full refurb., so a compromise repair may be worthwhile.
The only way forward would be to identify the movement in order to establish what parts are available for that calibre, looking in a book I own (Patek Phillippe, Roy Ehrharrdt Joe DeMesy ) it looks like a calibre 8L-80 which would date the watch from sometime in the 1940's case reference numbers and serial numbers on the case may make it easier to establish exactly which movement it is.
The problem may come down to money it wont be cheap to source the parts there is a clutch wheel listed on ebay at the moment  at £140.00 pounds for this calibre add the other parts into the equation and you will soon be heading to the plus £1000 pound territory.
the watch could be very valuable depending on case design, if it is a jewelled case it will command more if its a simple gold case then the cost of repair is going to probably be more than the watch is worth.
  • Similar Content
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
    • I did try that last time Rich , i traced the image from the Bestfit book which is the actual size. But its more difficut to cut the shape from paper than it is to grind the steel to shape. This way is pretty easy and the final shaping is done when fitting the part. There are a couple of things i will do differently next time, clamping the 2 pieces together with a drill press will help to hold while scribing the shape in. This was a bit tricky having only one hole, if using the pins and cork the drill size needs to match the pin diameter so there is no movement at all from the template. This movement hasn't finished frying me yet, damaged thread in the plate crown wheel hole and two rubbed in cracked jewels, thats gonna be much more fun.
    • 👍 Whats not to follow OH ?  You're every inch a pro and a true gent, i always enjoy reading your answers even some of the clock stuff that i dont have a clue about.
