ETA 2836-2 Auto Mechanism Issue
Dico
Hello All,
I just serviced an ETA 2836-2 which runs flawlessly up until the auto mechanism is put back on. Without the auto mechanism it runs almost a full 36 hours when fully wound but once the auto mechanism is on it stops intermittently every few hours even when its sitting still. The mechanism is seated correctly and I verified nothing is interfering with the balance. Any thoughts on what can be causing this?
Yup, this is a classic eta issue.. firstly, the rotor and reversing wheels must be as clean as physically possible..
the rotor bearing requires a very small drop of oil on 1 or 2 of the balls
each reversing wheel requires the smallest possible oil on the tip of each pawl where it contacts the mating locking surface inside the wheel, and possibly a miniscule drop between the wheel arbor and the free running wheel of the reverser (hard to describe, and sometimes this doesnt work)
I use 9010 to lubricate these, after epilaming, to make sure the oil doesn't sod off to places I don't want it ;-)
if after doing this, demagnetising, and it still makes the rotor "propellor", clean them, repeat the process and don't be surprised if you need to do it a 3rd time ;-)
if you do make it to the 3rd time, the reversing wheel may need replacing..
Tom
The Lubeta is meant to work well, unfortunately getting a single bottle of it into Australia is prohibitively expensive ($4-500) due to hazardous material charges.. the 9010 is what is used at the swatch group service centre here, and more easily available.
The lubeta does also leave a white non-uniform residue over the entire part, so isn't appropriate for watches with a visible movement.
Tom
Hi All,
So over the past 2 weeks or so I've tried cleaning and oiling the auto mechanism 3 different times...that didn't work
Change out the rotor completely to a brand new one....that didn't work
Change the whole auto mechanism including rotor to a new one....and that didn't work
I'm at a loss here....is there anything else that can be causing this god forsaken watch to stop ONLY when an auto mechanism is re-attached to it??
:startle:
Oops, I just realized you meant the main movement was stopping, I was just thinking you hadn't got the auto winding properly...
Check anywhere there might be a pivot being interfered with, (centre seconds is a common one if the second hand has been put on without supporting the jewel), that the train bridge is flat, and not being pressed on by the auto bridge, also where the auto transmission wheel post goes into the barrel bridge, there's an opportunity for pressure...
Another one that just came to mind, make sure the auto bridge isn't pressing on the regulator on the balance cock...
Tom
If the watch still runs for 36 hours without the auto then it is still the auto or auto assembly that is the issue. I have read many times that most auto wheels run better not being lubricated just cleaned. ETA developed Lubeta to address this but I would be very surprised if this was the issue. I would say it is a assembly issue. Is it possible to a post a pic or even better a short vid of the movement running and the auto rotation.
Thank you for all the great responses. Taking the advice of clockboy I’ve included 2 short videos so you all can see the movement, screws and how things are seated. In this condition shown in the video, the watch runs flawlessly.
As soon as the rotor is placed on it again it stops within 12 hours. I’ll post another video with the rotor attached. I’ve changed the whole auto assembly to a new one so I don’t think the issue is there. It must be something else. Could the mainspring barrel cause this?
7CAE1615-DF00-49CD-B7F8-B75405400A15.MOV
BD73A76B-151D-4C8C-924E-67262647F793.MOV
Hi everyone
Still having the same issue here. I noticed after the last video I posted that even after winding a few times the balance does not start moving. In fact I have to shake the watch to get it going and then it’s fine as long as rotor is off. Can that have anything to do with the stopping issue I’m encountering? Issue with the barrel?
Hi All,
I'm still troubleshooting here. Noticed when it stops its always at the 51 or 52 second mark. The hours in between are random could be as little as 10 mins or as much as 12 hours - but always stops at about the same seconds mark. What does this mean??
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
