Lathe Belts and Oiling
jdrichard
You can get the belting off ebay you cut it to length and splice it together by heating the ends  Mark has made a video on the subject :
3 in 1 oil is what I use for oiling the bearings on my lathe. The belt should  have  enough tension that it does not slip but not very tight as this will risk damaging the bearings
Is your lathe cone bearing type? And is it 3 in 1 like this?21ef233e779f8a50dabe3a7dbc17bfab.jpg
Where would i find belts for my new old boley lathe. And how tight should the lathe belt be? And what type of oil do i use to oil the lathe headstock and the lathe motor.
Thanks ahead of time.
Boley are still trading. Type in Boley watch parts and you should find their German web page. You could try contacting them if you can't find the specific belt.
Most belts for most types of machinery are set at a maximum of half inch deflection, if that's any help
Years ago I switched from the "welded" belts to seemless O-Rings. They are stronger, grip better, last longer, are inexpensive, and most importantly for me, they don't make a clacking sound every time the seam in the belt hits a pulley. I purchased mine from MSC but any industrial supplier should be able to provide them. As luck would have it, the cheapest belt material worked out to be the best for the lathe application.
david
For the lathe cone bearigs I prefer something a little thicker than 3 & 1 oil. I use hydraulic oil but a thin motor oil will also work. I purchase my hydraulic oil in a  5 gallon metal bucket from a hardware store. This is because I also use it as a solvent in a small solvent sink. For cone bearing applications a small should last several lifetimes. Small quantities can be purchased from an auto parts store.
david
david
Thanks David. Do you have an on-line source for your belts.
david
What is the specific criteria of the search for the MSC belt, or the product name and code
You may find this interesting
http://www.opensourcemachinetools.org/archive-manuals/watch_makers_lathe.pdf
Spindle oils (also known as high speed spindle oil) is usually thin (ie low viscosity) between ISO VG4 and ISO VG15.  Typically paraffin/kerosine is about ISO VG2 to 3.
This source may help
http://www.small-lathes.co.uk/Lathe-Oil-–-ISO-15-–-500-ml-Bottle-[Stk.-No.-WLO15500]/422.htm
Most other parts are medium viscosity VG68 to VG100 which are similar viscosity to say Moebius 9020 or a thin engine oil SAE 10 to 20.
The VG number indicates the mean viscosity in cSt at 40degC, (ie can actually be say 64-72 cSt for VG68)
  VG68 to 100  could also be used for the motor bearings which may require an oil gun (similar to  small grease gun but oil is used), being careful to inject a couple of drops only to avoid contaminating the electrical parts inside the motor.  Normally this when motor has plain bearings, later motors are normally grease lubricated.
david
david
Again, thanks. I think i am going to go with Mobile 1 Synth 0W20
JDRichard,
The diameter I like the best is 3/16 of an inch.  If you go the the MSC section on O-Rings you will find pages of different rings cataloged according to diameter and length. The rings are given a number called a dash number but there will be  an explanation on how to convert the size you are looking for to that number.
david
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
