Wrong screw stuck
TimFitz
Hi
Can anyone help me with this problem? I have a size 12 american pocket watch that has what appears to be the wrong screw in the nickle  barrel plate. I need to remove it. It won't turn left or right, the head doesn't protrude far enough to grab it with a pin vice.
13 hours ago, clockboy said:
i have not had a lot of luck with Alum. Can it be drilled out or is it too small. A picture could be helpful.
Are you making sure to heat the dissolved Alum powder?  Works best to keep it heated.  Ideal mixture is 4 tablespoons to a cup  of water.
  • Similar Content
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
