hi,
A friend dropped off his foreign Brietling, said had broken the stem.
appears to be a standard setup with subdials at 12:00/9:00/6:00
i have been trying to identify the movement, but i am struggling after the usual Cousins & internet search, in order to get a stem and crown etc.
I removed the dial to help with identification and in doing so broke the 12:00 hour recorder subdial spindle.
Any thoughts on swapping the movement, or general advice would be most helpful....
many thanks
I don't get the point of using an unusual euphemism, as there is no censorship here. Call it for what it is, a fake.
An original stem may possibly work, but I don't really know.
1 minute ago, Chopin said:
Have you looked under the balance wheel ? Could it be some sort of Baumgartner ?
LoL, it's a low grade Asian 7750.
hi JDM , i am learning and a good point on the euphemsim thanks.
guess first i try some chinese 7750 stems, then try to find a 12:00 subdial recorder wheel and replace that.
if not, then i try to replace the movement, but I checked cousinsuk movements but could not find a similar 26mm x 6.25mm movement.
hi Chopin, will check and confirm anyways.
thanks
I stand corrected, not an A7750, but some other sort of contraption with month / moon / 24hr.
From Cousins it's an DG3836IB, although the same money would buy a lot more Chinese quality and honesty on AliExpress.
Edited by jdm
Hello Yorkie,
Disregard the watch (or semantics) snobs and use whatever words you choose to describe the movement. Getting to your problem: Check O. frei as the have a large selection of chinese movements. I am sure Cousins UK does too.
It looks like it may be one of these:
59be7247c7bde_ScreenShot2017-09-17at8_59_22AM.thumb.png.5672d2711affc7671f93fd7e8ed8dae7.png
No snobism here, just calling calling things their name. I'm sure that is something you appreciate too.
The mov.t in question is not a small seconds one; I've indicated model and availability above.
Fake of course. The movement is based on the DG2813 which is based on the Myiota 8xxx something.
Nice accurate movement if properly serviced and adjusted that can be found in most low-mid grade replica watches.
Not a chronograph for sure :D
Edited by szbalogh
hi jdm, thanks for the clarification, i ordered replacement today.
Hi Noirrac1j, no worries with snobism, and thanks for the help.
this forum is superb.
I'm glad you've got it sorted out. I am a collector and have high-end and low-end watches, and don't own any replica watches, but I defend anyone's decision to do so. Besides, you asked for repair help, not input on whether it's  real or not!
Looking forward to your future posts.
Regards,
J
And help was given. In the end, you're still quibbling about nothing, when the OP has already extended his thanks to everybody. Time to move on, right?
Nobody is bringing this up except you @jdm. Yorkie already expressed his thanks to me , and you need to own your remark.  So what's you beef now?
J
That you started calling others snobist, and continued saying that judgment was given instead of help. And here I'm owning my remark again:
Now please, would you drop it and move on.
    • Good to know that Oldhippy is fine.  I wish you a fast recovery, we, the noobs, miss you a lot.
    • Managed to clear the short, cleaned and oiled the movement. Now testing for 24 hours before I case it up. The movement is so small that it's loose in my smallest movement holder.
    • @oldhippy - wishing you all the very best of recoveries
    • Looks like the kind of message that occurs when there are routing issues between your local network and the remote server the site is living on - there can sometimes be 20 or 30 hops and when there are issues some of those hops become unavailable temporarily for some people but for others where there is a different path being used the issues are not manifest. Another explanation, and this used to happen to me a lot with my ISP, is using the ISP DNS servers on your device or router sometimes is not as robust as changing to a public service such as 1.1.1.1 or similar. I was having a terrible time watching Youtube a while back - changed the DNS on my Apple TV to use 1.1.1.1 and problem solved. However, these issues tend to resolve themselves fairly quickly.
    • As mentioned by the other members, it’s a dismantle job clean and inspect the solder joints. It’s an older generation using the paxolin pcb  not the glass fiber ones.
