Disassembly of ratchet wheel secured with washer
Not sure how/why I started using 9415, must have picked it up from some forum or youtube I suppose and I used to slop this stuff on with my largest oiler... now I use my finest oiler and under highest microscope magnification, and I have seen a difference. what do you use on your pallet stones, epilame and...?
Actually a good question, I haven't thought about it before. -
I'm getting a little blip on a trace line at the moment and wondering if my lubrication isn't as good as it should be. -
Yes, in my experience, 9415 must be applied very precisely so as not to impair the amplitude. It must be checked at a high magnification. Before realising this I got less than stellar results with 9415 and preferred and got better results with thin non-thixotropic oils.
Hello watchfolk. Something i have wondered about for a while but never looked into it and i bet its really obvious but I'm going to ask anyway. The two trace lines on a timegrapher provided they are seperated enough, how do we know which line relates to which stone ? I've always assumed that the top line is produced by the entry stone.
