I've just stripped down a Seiko 7006a which looks to me to have the wrong size mainspring in the barrel.
I understand that Seiko only sold the barrel with mainspring as one unit and it is now unavailable, but was wondering if anyone knows the size of a suitable replacement mainspring as I can't find the spring dimensions anywhere.
Worst case I can work it out, but would be nice to know if there is an already accepted size replacement spring.
Here is a photo of the spring in the barrel, it looks to be taking close to 50% of the space within the barrel, which makes me think its too long.
Is it just me that thinks the spring is occupying too much space within the barrel?
39 minutes ago, ro63rto said:
Seiko never sold just mainsprings.
The part number you need is
201024 shared by the 7005, 7009 and probably a few more.
The problem is that barrel complete for these old watches are not supplied anymore, so one has to use NOS (if any can be found), or reuse from another mov.t. Of corse the MS can be measured, I suspect i's the same size as on the 7S / 4R series.
Anyway to me it seems there is nothing wrong with that MS, and I would be cautious before blaming it. An approximate judgment on its health can be had observing the shape it takes when uncompressed.
Edited by jdm
It fits these ones below.
7001A
7005A
7006A
7009A
7019A
7025A
Could you first try and put it all together and see how it functions ? As has been said maybe you shouldn't consider it the wrong part just yet...
The spring is not set, it just looked like more than 1/3 rd of the space was occupied by the spring, so I wasn't sure if it was original, or if someone had fitted the wrong size spring in it.
I'll clean it up and reuse it.
On the whole the movement is in far better condition than I was expecting as I know it had some water ingress and was then dropped in methylated spirits to remove the water.:startle:
The anchor and roller jewels are still glued in place and the only rust I can find is limited to mainspring click spring, the dial has some damage which I suspect is due to the meths
Do not take any "rule of thumb" as if carved in stone. Check pic below for a Rolex MS in barrel, pretty much the same I'd say. Maybe the 1/3 proportion was appropriate before metal alloys developed better.05_barrel.jpg
Edited by jdm
Thanks jdm, that made an interesting read.
So far I've not worked with any modern watches, this 1970s Seiko being the most modern watch I've touched so I am used to older movements where the mainsprings are shorter. I've learnt something new today now, which makes it a good day.
A measure of the mainspring gives me 0.95 x 0.115 x approx 400 with barrel diameter being 10.5mm so that looks pretty close to me.=
I will try and resuse the original spring, but first I need to make some spacers for my mainspring winder as it is made for much taller springs.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
