Aloha All ,
I'm not really a collector of clocks or pocket watches , although I have a few of each I picked up in my searches down different avenues .
I managed to pick up this Howard Miller Triple Chime Mantle clock at the swap meet for $65 with intentions to resell it on craigslist or ebay . I think the model is called ,"Bellingham" .
This particular clock has triple chimes that can be selected with a lever behind the dial glass and it can also be silenced with the same lever .  It has 8 hammers and what ever you call the things that the hammer strikes . What struck me is the beautiful tone of the chimes . The chimes that can be selected are called Whitt. , St. Michael's , and Westminster ,...I think . Please correct if I'm in error on these chime names .  Anyway , I am partial to the St . Michaels chime ,...very nice , melodic , and mellow .
And some Pics to share...
Thanks ,
Louis
Edited by ricardopalamino
Thats a nice clock.It looks like it has a newish case & dial. I would also say it is what is called a Napoleon hat style case and the movement has a floating balance which has the advantage of not needing to be exactly level for it to work efficiently.
The hammers hit what is called gongs. What you have is an 8 day floating balance underslung Westminster Whittington St Michaels chime. The style of hands are called Serpentine and the case is a style called napoleon.
Thanks for all the great Info fellows .
Clockboy ,  I may be mistaken , but I don't think the clock is that old . In my little bit of research I think I found an approx . date of manufacture and I seem to remember I was surprised that it was older then I thought it might be .
Oldhippy , you are , as always , a plethora of information .  I'm glad you chimed in .....Yuk Yuk..
Howzit vinn3 , ....what's a "tamborie" ?
The movement is a Franz Hermle 1050-020 rebadged for Howard Miller it is as already stated very modern. Franz hermle movements are date coded they use to have up until 1988 a two digit number representing the year 85, 1985 86, 1986 and so on, they then changed to a date letter starting off with A, in 1988 B, 1989, C, 1990 and so on. Look just above the Howard Miller stamp and see if there is a date letter that should give you the year of manufacture.
Edited by wls1971
6 hours ago, oldhippy said:
I would say its from the 1980's and upwards.
Its made of a combination including brass which is by old standards soft, the steel is also very poor.
Okay , now I see why it sounds so good . Nothing to hold it back .B)
    • Yep…This makes perfect sense. With that large a gap in the serial numbers, they were almost certainly machined on different equipment, hence one should have no expectation of any cross-batch compatibility. I’ll revert to the original bridge. Regarding bending the bridge @nevenbekriev, I’ll give it a try, but I may have to buy some better calipers. My Vernier calipers are only accurate to 0.1mm. Not very accurate.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
