Battery Warranty
After all the Crap i went through with My Swiss Army Watch i got out My Tissot watch and Ferrari ronda 5030 D, they both needed Batteries and i went to a Local Jewellers the Price was €15 and €22   Respectively  without warranty and they said that if i wanted a 5 year Warranty on the Batteries it would be  €22 and €30, IS this first a good thing to do so whenever ur battery dies in that 5 year period they will replace it, interested in your comments and about prices
Tools are 5 - 10 euros for all, batteries less than 50 cents each.
People normally gets batteries changed at small shops for 5 euros or less, leave jewelers their trade, that is selling jewels.
Edited by jdm
What do u mean by small shops ?
can someone send me a link for these tools please also i was afraid that if i might effect the waterproof seal in the watch
CousinsUK has a selection from £6 upto £125.
eBay
http://m.ebay.com/sch/i.html?_nkw=jaxa+wrench&isNewKw=1&isRefine=true&mfs=KWCLK&acimp=0&_trksid=p2056088.m2428.l1311.R1.TR11.TRC1.Xjaxa&sqp=jaxa
Different tool needed if your caseback are not screw types buy snap on instead.
Sent from my Honor 5c
Same issue, Last year I purchased a Swiss Army Watch for my wife in Switzerland. After 6 months it stopped because the battery was just dead. New battery fitted and it now runs fine. I guess they stay in stock for a long time before being purchased.
PS the movement inside was a ETA
Anyone opening the watch will affect the waterproofing. If you want the watch sealed and tested, then that's a different level of cost.
Neil
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
