Barrel/main Spring Lubrication Survey...
By LittleWatchShop · Posted
Seeing is believing, I suppose. Can you cite a 2Nxxxx part? -
By WatchesUAE · Posted
The Audemars Piguet Royal Oak is an iconic luxury watch known for its distinctive octagonal bezel, stainless steel construction, and integrated bracelet design. The 34mm version is a more petite option compared to the larger variations, catering to those with smaller wrists or a preference for understated elegance. The blue dial adds a touch of sophistication and versatility, making it suitable for both formal and casual occasions. -
If you have an apple device and download the app linked in @deni2s's post the search function works properly.
ok, have you try a watch that twist the bezel to open it? and use what tool? I try to pry the bezel and it does not work.
This is the link I use to Ranfft : https://web.archive.org/web/20230305223408/http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk The search function doesn't work, so the link should show all the movements.
