Summer project.
I love mechanical things, not least the watches, clocks and other mechanical hardware. To be able to repair watches have been a wish in a really long time. Unfortunately I have not had a real place to practice and must recognize that doing it in the kitchen just cannot be reconciled with the family.
That is why I am now going to remodel our 70 's garage into a workshop and hobby room for joy for me and the rest of the family. It is anyway too small for a modern car.
The garage is at about 6.8 x 3 m. and there for approx. 20 square meters. The redevelopment will be extensive as i have to make heating and floor heating window and a small kitchenette. I am now almost finished clearing out the garage so that the work can begin. I will put up some pictures every now and then as the project progresses!
try to get a window facing the sun rise.  have fun.  vinn
Unfortunately it is not possible right now. In the first place, I get a window to the West, later perhaps a narrow one facing north! Over time maybe a towards the East!
No reports from me for a long time but next week my family is leaving for a week and i will be back in business. Lots of plans including finishing a 1972 München pin lever watch (new baalnce turned), servicing some watches (Vostok Komandirskie, Ricoh auto, HMT maybe...), some enameling experiments, making some tools (faceplate for mainplate and case turning) and.... designing my own brand :)
At the weekend i continued to work in the workshop. The load-bearing beams hase been attacked by boring beetles. If they are still active or not is hard to see, so I chose to smear with a means to be sure they are not coming back. 7.5 liters "PROTOX INSEKT" has come on with a brush. I have also created wind screen between the beams so that it does not blow into the insulation when it comes up. Today i started on the electrical installations in the ceiling, among other outlets for powering LED panels!
    • Couldn't see it on the tech sheet , picture is a bit fuzzy though . Is that to keep the pinions pressed on Marc ?
    • Doctor, If the train turns when hands setting, this means that the train is not blocked. And this is true for all kinds of trains design. The train is normally blocked by the lever. So, put the lever in place and try again. If the train turns again, search where You have placed some wheel upside down and it is not meshed with the next one in the chain. The other thing is the amount of friction that is needed to overcome when setting hands. Yes, the friction part here is in the great wheel, and it needs lubrication. If the parts are dry, then friction will arise, seizing will happen and thus risk of breaking of teeth in the train or breaking of joint wheel/pinion. I don't know this calibre, but I guess the clip is part of the friction device. But for sure it stays tilted, which is not normal. So, pay attention to it and see what is wrong there
    • It most certainly should be there, but it should fit better than that. Here is what it should look like.
    • This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel?
    • It shouldn't be attached    The pinions look independent of each other, not in alignment,  but the clip is bothering me or have you just placed that on the pivot end?  Found a cannon pinion maintaining clip in the tech sheet, is that the disk on the end and is broken.  Whatever happened to exploded diagrams 😠
