Breitling Die Set
I have never come across this make and I suspect most members on this forum are the same. Personally unless you are anticipating servicing a lot of Breitling watches then it is a big outlay. I purchased a similar tool for Rolex watches and it did not work and slipped under pressure. In my opinion it would be better to purchase a horotec case removing tool and just purchase the dies as and when you need them. I purchased this tool and have just added as and when needed. Some of the dies I have only used once.
591f3df361aa4_ScreenShot2017-05-19at19_46_28.png.fec1c2843764a80794808c4442fff5a4.png
Just recently got supplied with a simular if not identical breitling kit from my company, not sure how much it cost, i doubt it was that exepensive. I haven't had the chance to use them, however I have been told the kit is not sufficient to open all breitlings, some of the dies wont properly fit some models.
Edited by Ishima
Thanks for your replies
How does the Swiss style case opener compare with the Horotec?
Do the Horotec Breitling dies fit the Swiss style ?
Generally all dies are made for the Bergeon type. You can find the same Chinese tools for cheaper on aliexpress. They work pretty good.
I am not familiar with a Samsung but I presume you just attach pics via this which is at the bottom when creating a post.
Horotec is deffo good quality,Im near London and
HS Walsh has a counter in Biggin Hill so I will take a look before buying tools in future
I am no IT expert but some here are. Normally a triangle is showing that it is a unrecognised file or file format i.e. you should use jpeg images. Is the Samsung a mobile some here will know how to use.
This conversation is drifting into an area of chat so any conversation re PC, s etc should be in the "Chat section"
How do the Horotec and the Bergeon 5700 compare?
For one, the horotec in the picture above holds the case with the four plastic posts, but the bergeon require to remove the bracelet to hold in the lugs.
There is an entire thread dedicated to value case openers that you can read. My Chinese one works fine. They also copy horotec of many types.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
