Any Advice On A Nice, Accurate Vernier Gauge?
I tend to use Mitutoyo, they are excellent..........but I bought a cheap Chinese one and in all honesty it works just fine. Whatever you make sure you get a metal one and not a cheap plastic one.
The cheap one was the same as this one:-
http://www.ebay.co.uk/itm/150mm-ELECTRONIC-DIGITAL-CALIPERS-VERNIER-WITH-LCD-INC-HARD-CASE-/290679682771?pt=UK_Measuring_Tools_Levels&hash=item43addbf6d3
Edited by Geo
ooops! I got the cheapo! In any case, I haven't had any issues with it either, but the all metal one will be my goal if Bergeon -- which keeps coming out with more and more different tools -- allows it!
FWIW, I've got a Mitutoyo true vernier scale caliper (metric and imperial), an import dial vernier caliper and a Brown and Sharpe 1 inch micrometer with carbide faces all of which I use in the machine shop that range in price from $20 - $30 CDN although the micrometer was not bought new but second hand.
I find the imports are fine too for the most part but have heard if you buy a digital caliper to keep an eye on the batteries as they tend to leak and ruin the internals.
Starrett is the ultimate in some machine shop circles but very, very pricey.
Rossco
I have a digital Mitutoyo, and a conventional Moore and Wright. I have had them for 26 and 29 years respectively and have never had an issue with accuracy or battery usage. I have changed the battery in the Mitutoyo 10 times over the years and it does a fair amount of work.  As for micrometers I user Moore and Wright. as with the conventional vainer callipers I have had my micrometers for 29 years and again never had a problem with accuracy.
At the beginning of the month I bought a JKA FEINTASTER comparator in as new condition. For this horology lark it really is the business. I have a couple of jeweling jobs to do and having watched Mark's video, I thought it was the way to go.
I would love one of these, but the budget and wife, won't allow it.
So I bought a reasonable quality 0.001mm micrometer and formed a small piece of aluminium around the shaft, which will also slide to allow normal use of the tool.
It is excellent for Jewels as they sit flat on the arc of the sleeve.
What a delightfully simple yet effective solution to a fiddly problem. I like it!
I use a cheapo Chinese vernier which I tend to use a lot and is great for most measurements. However I have a Mitutoyo micrometer for more the accurate readings. However I wish I had a Comparator as the micrometer can be real fiddly when measuring jewels etc.
Posted 30 July 2014 - 10:24 AM
Good choice. I purchased mine from a seller in Germany on the eBay.de website - it cost significantly less than buying it here in the uk. Think it cost me about £100 all in with postage which is a bargain but I had to do a little work on it to make it perfect. And the wooden box is prone to splitting but a bit of PVA sorted that out.
  • 5 months later...
    • You're right Rich, throwing money at something that is practically worthless. I've had i happen a few times, its  disappointing, but a lesson learned in checking everything out before you put in too much effort. I'm still tempted to look through a load of balances and wheels i have to see whats doable with the genuine staffs, I'm thinking the  wheel that it came with is not genuine, it's had it weight completely hacked down.
    • Ok thanks  it was just the brass cover next to the previous 3 keyless parts. Normally i wouldn't have expected that to be used to identify,  but I've searched American,  German and French part catalogs and coming up with nothing for the set lever,set spring and  yoke. I will have another look later today. There is another way but you would have to measure the stem very accurately.
    • The diameter of the dial side is 40mm, and the other side 36,5mm. Here is another picture
    • The chronometer on the dial might just be a brand name, looking back yes i was mislead by the mention of Remontoir inside the case. Still not sure why it says Ancre Remontoir which translates to anchor winder, i imagine that means lever winder which still suggests to me 2 winding springs. I'm sure i have that same watch with chronometer on the dial ,I've never ventured inside it. My missus looks after 90% of my watches , so i will get hold of that one and have a look inside. Haha no not a remontoire, looks very basic.  Good to see the keyless works, can you measure the plate size to cut down on the search for them. Can you lay out that brass bridge cover as well please next to the other 3 pieces.
    • That's true. It is not a chronometer. As a matter of fact, I got it with another timepiece which is e real one, and only that (not a watch). I add a few pictures of my Chronometer / watch. no indication of a brand ...
