First Lathe Project
Tmuir
Last night I completed my first simple lathe project for my watch repair course.
This is the first time I've used a graver on my lathe to make anything to a set dimension.
I'll be the first to admit it has a number of flaws in it and I still need to improve a lot, but for a first try I think its ok.
I started with a 1/8 inch diameter brass rod and had to turn it down to 1mm diameter for 1mm, 2mm for 2mm, 2.5mm for 2.5mm and 3mm diameter for 3mm, giving us a total length of 8.5mm.
Here are the results below.
Photo of part, I slipped facing off the end causing the scratching at the end of the larger diameter, also note the mistake at the transition from 2.5mm to 3mm caused by me squaring off the end.58f2ec25d57c4_latheproject1.thumb.jpg.a3e35132897818ce9e322f558c629444.jpg
Total diameter should be 8.5mm, mine is at 8.42mm, so 0.08mm undersize.
1mm diameter is at 0.99mm
2mm diameter is at 1.99mm
2.5mm diameter is at 2.49mm
3mm diameter at 3.01mm
I still need to do a lot more practice, but atleast its a start.
Certainly a good effort for a first attempt. I can only imagine my first attempt turning to those tolerances. I was how ever, casting more than a few admiring glances in the direction of your lovely JKA Feintaster...a very nice piece indeed. To bad the cost of one is so high. Definitely on my wish list.
Ron
Ron
I got lucky with the JKA.
I was on holidays in the UK last year and on my tablet saw it been listed from Germany with a BIN of around £75 and snapped it up very quickly as they usually sell for 2 times or more than that. I bought a few tools, books, a couple of clocks and watch movements on that trip, but this was definitely my best buy of the trip.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
