I have just acquired a Seiko 5m42-0h20 kinetic watch , sold as faulty. It runs for a while but stops after about 10 minutes after the watch is stationary. A quick shake and its going again. I assume that it probably just needs a new capacitor(battery) and a spot of lubrication to get it back to normal use. It is in immaculate condition, not a mark on it or a sign that anyone has ever had the back off. I have serviced about 6 Seiko’s before, all either 7S26 or 7S36. I assumed that the back comes off in the same way as the Seiko 5s, but I cant budge it . Does anyone know if these have a different type of back, or alternatively if they are a normal screw on type does anyone have any tips to get it off? I am using an adjustable three pronged back removing tool, or trying to.
When the back is extremely tight the Jaxa tool won't do, it will slip and cause more and more scratches. You need a type 5700Z opener or bring it to a watchmaker that has one.
Thanks jdm I have just had a look at the 5700Z on cousins site, a great piece of kit but beyond my means, looks like I will have to find  a friendly watch maker!
I've got a Seiko Kinetic, different model. If I remember correctly it is actually a snap on case back that looks like a screw on. Perhaps yours is as well? Might be worth giving it a try.
Stephen
Def a screw back not a snap on. Never seen a Seiko with "fake" screw back.
Fit the watch case in a vice with plenty of padding (cloth?) And use a good quality Jaxa wrench. Adjust it to the correct size, place it and use the palm of your other hand to put downwards pressure then applying CCW rotation with your other.
Don't jerk it but steady pressure.
9/10 times this does the trick.
Sent from my Honor 5c
Check "value case opener" threads for alternatives. Unfortunately it's one of these things one thinks can do without until you find you can't.
Sometime the Jaxa is not enough, because having (stupidly) one handle only, it makes impossible to place force perfectly vertical while turning at the same time. And at each failed attempt it makes deep scratches even if plastic bag is placed in between.
Hence the palm pressing down on the tool.
tool.
What I'm trying to tell you is that is not enough, because an human hand and arm are not a machine. I wouldn't have spent $150 if I could have done without it.
You could always try the old "super glue a nut to the case back and use a spanner trick". It generally succeeds when the Jaxa style wrench fails
Hmm, not scratched one, yet.
I've done around 11 or 12 mine and friends up to now that we're almost welded on tight.
Hope you haven't jinxed me now [emoji1]
Thanks for all of the suggestions. As the watch was from ebay and didnt cost much I was reluctant to spend a lot on a 5700z type tool,(which would undoubtedly be easier to use and kinder to the watch) I could  buy a new watch for that money. I put it in a watch holder in the workbench vise and with all my weight pressing on the jaxa tool before trying to turn it slowly applied pressure and it opened ok.
The battery (sorry capacitor, got to get used to calling it that because The Royal Mail wont carry LI-ON batteries) only measured 0.5v.
The rotor was a bit stiff so i have lubricated the whole generator section , fortunately this web site has the documents for the watch. It is rotates much better now so I'll see if its any better now before ordering a new Capacitor
It is a rechargeable battery indeed. Capacitor was the previous technology now phased out, but you can find some sources stll using the name.
Hi everyone. Is there anyone with much experience of these watches. As previously mentioned the component was replaced and the generator section cleaned and lubricated. The info I got said that when the button is activated to display the power reserve, if the second hand moves 20 seconds then you will have enough energy to run about two weeks. I wore the watch every day for two weeks to get it fully charged. I set the date correctly to see when it would stop after no further use. After two weeks it was still running and indicating 20 seconds. I then went on holiday for a month and it is still running and showing 20seconds, I haven’t moved it ,holding it still when the button is pressed. After all that , what I would like to know is how long is the watch likely to keep on running before stopping. Part of me wants to leave it and see how long it goes for and part of me wants to use it.
The information you have is what the old Seiko manual used to state for these watches, the new capacitor you have fitted will be a lithium ion battery and will hold far more charge than the old type approx 20 to 30 times that of the old so the charge will last far longer they are also quicker to charge than the old capacitors.
Edited by wls1971
  • 5 months later...
An update about the kinetic watch , I have not worn it again since taking it off half way through April this year and it stopped on 11-11-17. It was indicating two weeks reserve when I took it off and it ran for seven months without being moved. I think if it originally ran for two weeks when it indicated that it would, then the change from the "capacitor" to the lithium battery is a vast improvement. I think I will remove all of the dust and perhaps use it now and then.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
