Hi All
Not long ago I was given and old Timex that belonged to my grandfather. It came to me as pictured and I haven't had the time to look at it since, I know very little about Timex watches and I am not even sure what model or what year it was manufactured in. Its missing its stem/crown, so I would like to identifying a suitable replacement.
I would be very grateful if anyone could shed some light on this watch or even point me in the right direction so that I can find out if the old thing will still tick over and hopefully put it back into daily use.
Many Thanks in Advance
DSC_1689.thumb.JPG.99943fa71650d7ddeb2b2c254534a6e0.JPG58cd3a257c059_DSC_1686(2).thumb.JPG.0bbf4fb4b938367b6dac05539b0f3d31.JPG
There are some numbers on the dial at the 6 o'clock marker, unfortunately your photo isn't clear enough for me to read them. If you could post the numbers, I can tell you more about the watch.
I have looked at this watch several times today and completely missed the numbers below the 6 o'clock marker. Only after looking at it through the eyeglass did I have the 'aghhh' moment. :unsure: Obviously not looking close enough.
The numbers read 26761 2573
there also is a timex forum.   i like timex, but  thru the years they seem to change the stem removal method.  there is also a timex dating chart on line.  Roy (of the watch forum) is the expert.
The first 5 digits relate to the model number, the next 2 the movement and the last 2 the date of manufacture (1973).
The movements were not intended to be serviced and parts are virtually unobtainable, but if you'd asked last week, you could have bougt this for it http://www.ebay.co.uk/itm/NOS-TIMEX-Replacement-Watch-Movement-M-25-In-Original-Container-/381990989165?hash=item58f06fed6d:g:HMcAAOSwopRYkkwH
If you want to get it going then I suggest either looking out for a donor with a stem, or fitting a Chinese movement.
Stuart Baker is correct, the catalog number is 26761, It's a Marlin (water resistant) calendar model. A #25 hand wind movement, and the year is 1973.
It uses a one piece crown and stem, I'll check and see which one when I get home this evening. It might be available, it's possible that I even have it myself.
Cheers!
Thanks David, Vinn and Stuart
I now have the model, date and a service manual for the movement.
Just need to source the Stem/crown and get it serviced, something I might attempt myself as I need to start somewhere....
Cheers for the quick responses !
I think I've located the crown & stem that you need. Since yours is a UK model, I don't have an exact reference, but I believe that I have found its American cousin, 26760. As far as I can tell the cases are the same.
The Timex part number is 025-060054
The crown and stem can be found in the material system 401/1 TX1K, listed as compartment 10.
I've attached some pictures, and if you want it just send me a PM and I'll mail one off to you.
The Crown and Stem turned up today, Many Thanks David, very much appreciated.
Like a child I took the part out and matched it up.
It fitted perfectly. However, It would would not stay in place.. after taking the cover plate off and looking through the loupe I spotted why I believe it was missing its crown and stem in the first place, and perhaps something I should have noticed before (rookie)
The Set Lever (pn:443) has been damaged and no longer retains the stem at all.
So, I am looking for the part, once again.
On a positive note the watch is ticking over and keeping good time :-) #
Glad you got the part and it worked!
Do you have the screw? I might be able to come up with a lever, I have a few parts movements.
Let me know if you want me to look.
Yes, I removed the damaged set lever and then replaced the screw until such times as I can source the part. Only option I have so far is a donor movement on the 'Bay', and I am currently waiting for it too run its course.
  • 1 year later...
On 3/21/2017 at 3:22 PM, dadistic said:
The crown and stem are on their way, I posted them Monday afternoon.  Let me know when they show up.
Have Fun!
Hi,
I was wondering if you had a stem and crown for a 1964 Marlin (gold case) model 20242464? Or know how i can get one. If they are 2 pieces, my watch has the stem but the crown is broken.
Thank you!
As per PM, I don't happen to have this one. Keep an eye on Ebay, or maybe someone else will have a lead for you.
Sorry, and good luck!
Edited by dadistic
21 hours ago, wadsbrau said:
Hi,
Thank you!
 I have it - 20242464 It is not a two piece split stem.  The case is a front loader-
I meant 2 pieces as in seperate crown that screws onto the stem. But, Any idea how i could get one?.
thanks
  • 1 year later...
I have a mid to late 60's Marlin of my own and am in need of the single piece crown and stem to get it running properly again. Is there a site you recommend for trying to find them? Does't necessarily have to be OEM. Thanks in advance.
  • Similar Content
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
