Could A Wrong Battery Ruin A Watch?
Update:
Bought a new Silver Oxide battery and fitted it. Nothing happened so I started adjusting the time advancing the hands 48 hours, nothing.
Then I tried pulling the crown fully out and pushing it back multiple times.
EUREKA! it started ticking and hasn't stopped since.
Thanks to ALL the advice given :D
Now to tighten up the loose links in the bracelet.
well done, don't forget even a quartz watch has jewels that need oiling, sometimes they dry out & can stick so need an oil. but more likely a bit of debris in it somewhere.
Links on bracelet all nipped up. As good as new except for where the colour has slightly worn away. Can't wait to return it to her.
Well done mate. I am sure she will love it :)
  • 2 years later...
UPDATE
Took the movement out to put case and bracelet in ultrasonic.
Once I was ready to refit, noticed the stem wouldnt stay in.
Took a macro pic and saw a piece sticking out beyond the circuit board. Should it?
Maybe I need to replace movement. How much for a new ETA V8 quartz?
1 hour ago, ro63rto said:
The arrow points to the dimpled stem release button but whay does the plus sign mean and what is the screw for on the opposite end?
Means positive voltage and the screw likely holds the circuit board in place.
Ok. Just seemed a bit odd that the release button was being pointed out by a plus sign.
Thought maybe the screw was to release the button as it now won't pop back up.
Probably old oil is keeping it down. I barely pressed it to release stem.
did you know that an accutron will run with the battery reversed?   i bought one that  way.  it had been running for months.    the quartz watch may not,BUT  i  don't think reversal of current could damage it.?   vinn
Googling reveals that the ETA 956.114 Has been discontinued replaced with the 956.112 Then I've attached a technical sheet with all the specifications repair etc. should answer a few questions.
Then using a wrong battery usually isn't going to be an issue but it makes a great excuse if the watch doesn't work. Quartz watches have similar problems that mechanical watches have like lubrication dries out. They're considerably more sensitive to foreign matter floating around they don't have the energy of a mainspring powered watch. Then if you can drop the watch or hit it with enough force it's possible to break the quartz crystal than the watch is totally dead. Plus unskilled battery changers have a habit of scratching the coil which breaks the wire.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA-ESA_956_114
613_ETA956.032,956.042,956.102,956.112,956.122,956.402,956.412.pdf
Thanks John but the second link to the pdf doesn't seem to work. It looks like its been lumped into one long string in tapatalk.
Long past the worry about the battery.
Just the setting lever button not coming back up.
Downloaded the service sheet from Gleaves so will attempt a mini stripdown tomorrow.
Over the years if Ive found a battery leak, its invariably been a Renata battery! A search on the web about watch-battery leaks tends to confirm that Renata do tend to leak,--Not good for an expensive movement or a rare coil....
I use only Sony or Maxell myself or at a push, Rayovac, none of which Ive ever seen have a leak--Perhaps though, You know different!...
One thing is certain--Cheapo pound-shop Alkaline batteries have no place in a watch, Reminds me of a seller on ebay with a nice Omega Seamaster with ESA 9162 tuning-fork, complete with an AG-10 pound-shop special--I Didnt bid on it!
Edited by Alastair
An Accutron tuning-fork Always has the positive terminal (main case of battery) Downwards in the movement--giving the impression its wrong way round, they certainly Wont run with the batt reversed--In fact a reversed batt can do damage to the 0.22uF Tantalum cap in the circuit, if its left in the wrong way for some time, a PITA to change on a 218x calibre- In fact, Most things are a PITA with a 218!...
Only the Accutron Spaceview that Citizen re-issued and made 1000 of as an Anniversary watch in 2010 has the batt in conventional orientation--with the pos uppermost......
    • Rich, this one seems rather regular movement to me. Yes, what You describe exists, but I doubt that the one on the picture is something similar.
    • @Neverenoughwatches Many thanks for your remarks. As I wrote earlier, I was a bit reluctant to disassemble this movement, and you gave me further motives to be careful. I'll just remove it from its case so as to clean it a little.
    • I am not sure for the terms in english, but if I directly translate from Bulgarian or Russian, there are 'magnetic soft' and 'magnetic hard' magnetic materials. The first group will not get magnetised, thow they will be attracted by magnets. The soft iron for example. The second group, like hardened steel, will get magnetised. So non magnetic hairspring aloys belong to the first group.
    • Looks like it is only dirt. If rust, then this means the strenght of the spring is reduced in places with rust, so the spring is damaged and useless. Only light surface rust, which is rather residual from other places activity of rust can be cleaned, and no chemicals that can etch the metals of the spring aloy should be used Be aware that this usually happens when the dial/hands have radium lume! One of the pivot looks little bent. Not that much to prevent the movement from working, but may be amplitude will be a little bit smaller when this pivot down, resing on the cap stone. Bent pivots always means the balance is out of poise, but it depends on the severity of the bent. Yes it can be straightened, but at this point I will advice to leave it as is and check how the movement performs.
    • Hello, I'm after some help on getting a functional tool for removing and replacing case tubes, the friction fit type not the threaded type. I have previously owned two Chinese Ali Express tools, which worked, but in each case after using on a watch case with an angle the watch had to be manually held perpendicular and when this angle was not perfectly aligned the pusher pin inevitably received a slight side load and the tool body was damaged. Due to the fact that the hole which holds the pusher pin is so close to the end of the block and the material wall is so thin: The result was that the hard pusher pin stretched and deformed the hole and the pusher pin was then slack and no longer perpendicular, and eventually the material split altogether. After I looked at the tool I realised that the block the hole was machined into was aluminum, this coupled with the extremely thin wall made this hole very weak and prone to the deformation and damage I had experienced. I looked to another reputable supplier (see below) who advertised their tool as "all steel" and I even contacted their customer support who confirmed that the block in question was made of steel. I was very disappointed yesterday when it arrived and found that it was in fact aluminum and not steel as promised. I could tell by the feel of the material (weight) and confirmed with a magnet which would not 'stick' and have since requested a return/refund. Assuming the return/refund goes smoothly, I am still left with my original problem of not having a tube pusher tool - does anyone have any recommendation for a tool which will work and will also stand the test of time?
