Seiko 7009A Problems
Hi
I was wondering about bent pins or an out of shape HS too so bought a new balance assembly; unless the new balance is faulty.
I marked the balance wheel so that I know where the impulse jewel is when I replace it. So, I know the impulse jewel is at least in the right direction.
One thing is bothering me about the balance: It doesn't turn all that easily all the time.
BTW - I've tried lubrication of the pallet stones and the balance.
It's a mystery...
Dave
Yes sometime a Seiko balance can really act up. I have one on the bench that stubbornly stopped running while I was trying to correct the hairspring which was overlapping. I hope to eventually find what's wrong, at this time I simply don't.
If I lie the balance cock upside down on the bench with the cock facing west the hairspring will swing freely when it is a smidgen north of the jewel assembly hole because at this point the spring is centred on the balance wheel. The HS isn't centred when the pivot is in the hole.
It's almost as if the jewel assembly holes are off by 0.5mm.
Very strange.
Maybe I should break out the old ball peen...LOL
Dave
Then the HS is distorted, even if it's a new one. Normally a so slight distortion is not enough to prevent it from oscillating, but as I said, these are really delicate and capricious things, ask me ho do I know.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
